Metric screws
Metric screws
Why is GM/Chevrolet using metric screws on the C7. To change out the airfilter I needed a 7mm socket.
Just wondering!
Just wondering!
Received 3,818 Likes
Because cars are made using metric. When someone says the USA is the only non-metric country, they are wrong. The USA is bilingual in that regard. You can't even buy a measuring cup that does not have metric embossed on it. Ever been to a hospital lately? (I hope not.) They weigh you in metric. All cars, except really old ones, have a metric speedometer. What size is your engine? Is it 378 cubic inches? Well, yeah, but we call it 6.2 liters. And for the record, a liter is about a quart, if you need a quick approximate conversion. About the only thing we don't readily get is temperature. 20 degrees is cold in Fahrenheit, but hot in Celsius. But the fact is we're a stealth metric country.
I'm guessing you haven't performed your own maintenance for a while; my 1995 Z28 was mostly metric!
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
Elmer
Received 5,217 Likes
Where've you been...for the last, HOW MANY years, Mr. van Winkle???
It has nothing to do with where the parts are designed or produced. The OEMs set engineering standards. When I started work as an engineer at a tier one automotive supplier in the early 80s, engineering was a mixed bag of English and metric. This transitioned over to all metric pretty shortly after my start. It has been all metric for many years.
Actually I believe that the U.S. Congress officially adopted the metric system way back around 1866 but it took a while to actually be used. But then again Congress does do everything at "glacial speed" except spend money.
Go buy and OEM part from your Chevy dealership.
It will have a Made in Mexico or Made in China label on it.
The chart does not show either of these.
I am pretty sure GM is not making parts for the car and parts for replacement in two different locations. That would not cost effective.
That link seems wrong. Go buy and OEM part from your Chevy dealership. It will have a Made in Mexico or Made in China label on it. The chart does not show either of these. I am pretty sure GM is not making parts for the car and parts for replacement in two different locations. That would not cost effective.
Received 19,307 Likes
'20-'21-'22-'23-'24
Screws/nuts and bolts have been metric on the Vette for a long time.
They can also be amusing. Some years ago there was a study demonstrating there are more U.S. parts and labor in a Honda Goldwing than a Harley. I have no idea if this remains true
