Valves are pretty clean
While installing my ported intake manifold I wanted to be sure I checked all the valves to see if they were getting gummed up with oil because if they were I was buying a catch can
They all looked pretty clean and there was hardly any oil in the intake manifold either . The "white " you are seeing is the light from my LED flashlight reflecting back
Dave
Dave
The following 2 users liked this post by Dcasole:
mammoth713 (03-20-2019),
Rebel Yell (03-18-2019)
Good to see!
How many miles?
How many miles?
Around 10,000 , this is my new motor that they installed after I dropped the valve . I was really anxious to see if I needed to go out and buy a catch can but after seeing this ... it can wait a few thousand more miles
Inside the old manifold was hardly any trace of oil ....
Dave
Dave
right, catch cans are only for engines with oil induction issues. Either because the pcv system has failed somehow, or was installed incorrectly, or was engineered poorly, etc..
A healthy motor with proper pcv should never use a catch can. Even if just to keep others from thinking there was something wrong with it... (I Would never run one visibly because I know what they are for and it isn't something I want others to know about) i.e. its a hygiene issue for the engine and the motor is embarrassed about the problem
That being said these engines due better than some other engines in terms of accumulation of crap on the valves over time. I removed my intake at 33000 miles and had so little gunk on them I didn't bother cleaning them.
USCG (03-18-2019)
A properly operating PCV system will still allow ingestion of oil into the intake tract from the crank case. I would argue the exact opposite point and say that all engines should have some kind of Air oil separator to keep these oily vapors from entering the engine. The system I use collects on average 6oz of oil from the PCV line per 5000 miles. I wouldn't want that going back into the engine at all as it would oil serve to dilute the quality of the fuel can get stuck to the
Dave
JerryU (03-18-2019)
While I'm not running a catch can on my C7, I wouldn't call 10K miles enough use to really evaluate. I have 57K on my car now. There are folks with nearly 200K on these motors and nobody has mentioned needing a decarb procedure like some of the German cars need.
Dave
I wish we would see more pictures like this, a lot of other car forums (for other makes with direct injection) have tons of posts with pictures of their intake valves (and most of them look pretty horrendous, check out a Subaru WRX forum for instance) I'm pretty confident that the LT1 doesn't suffer from any problems with excessive carbon buildup on the backs of the intake valves, but seeing more pictures would still be nice (I'd love to see the intake valves on an LT1 with over 100k and no catch can for instance)
Dcasole (03-18-2019)
How would you know if you had an issue or not?
All LS/T valve covers have had separators built into them. The problem is that is not where most of the oil comes from that gets into the intake. It comes from the PCV.
You'd know if the car started to run poorly or was down on power from reduced airflow.
Received 1,762 Likes
No LS had separators like the LT has. I owned 4 C5s with one being a full road-race car. I'm familiar with the LS systems. The "PCV" is a system consisting of the valley cover (also with an oil/air separator) and the valve covers. It allows crank vapors to leave the motor and be re-ingested and burnt up while letting fresh air flow in. It's not the valve covers and then "the PCV".
The point is to take care of the problem before the effects are noticed not to wait until there is a problem. Keep it clean now and keep the oil out of the combustion process and the car will run better for longer with fewer issues.
The baffles on the LT engines are far more elaborate than on any LS engine. That was my point.
Received 3,043 Likes
St. Jude Donor '05
Dave
Dave
