Delco filters say + 3/4 to 1 turn on the filter casing, but OEM says 22 lb/ft in the manual. 22 lbs is way more than 1 turn from gasket contact. What do you do? Personally I've always done contact + 1 turn and it takes everything I can give it with a clean hand.
EDIT - My concern is not removal... that's simple with a filter wrench or the oil filter socket I have. My concern is over-torquing the filter and damaging it or the gasket.
I've probably done a couple hundred oil changes over the last 40 or so years including 3 on my C7. Always have done 3/4 - 1 turn after contact. Never had a problem except the one time I failed to see that the seal from the old oil filter stayed on he engine, thus getting pinched by the new oil filter and leaking. Unfortunately that happened on a motorcycle and things sure got interesting after the rear tire got soaked with oil!
I've been changing my own oil for probably 50 years never use a torque wrench. I just do it by feel when I think it's tight enough I stop. Never had a leak. Same with oil pan drain bolts.
I paid ~$150 ea for three torque wrenches, 2x 3/8 drive that reads from 10 in*lbs to 25 ft*lbs, and 18 ft*lbs to 120 ft*lbs, and a 1/2” drive that reads from 30 ft*lbs to 200 ft*lbs.
Thats a lot of $$$ invested in 3 tools that basically does similar things. You bet I’m going to use them as much as I can.
Torqued to 22 ft*lbs with the “micro” torque wrench.
I had to remove one filter that had been tightened to 22 ft. lb. (or whatever, that's what I was told), and I literally twisted the steel can, which warped the base and finally released the seal. I've always used 3/4 turn after contact and never had a problem, AS LONG AS I USED A GOOD FILTER. Once I had to replace a filter with a Fram (not my favorite, but they're normally OK), but this time there was some problem (couldn't tell visually), but after replacing it normally it started leaking after a day or so.
No I went how I always do with filters, not by torque. I didn't torque the drain bolts either, but sure seemed like they werent torqued to spec by the factory either. Easiest oil change ever I thought.
I have change my own oil hundreds of time since the 80s, and ever single time I have tightened the spin on filter by hand well beyond initial gasket contact, usually in the 3/4 to 1 full turn range. 95% of these oil changes have been with AC Delco filters. Never once any leakage. Not one.
Until this thread, I never knew there was even a torque spec for spin on filters.
Same here. It seems to be about 1.5 turns feels right. I know real scientific huh? If it leaks I assume it going to happen right away so before the car comes down I start the engine and confirm all is good.
For wheels I always use the correct torque amount because its harder to judge the correct amount and a wheel coming off is a much bigger problem then an oil leak
Yep, 3/4 turn here. Pressure is low at the filter and it doesn't need to be super tight. Had the double-seal syndrome once on my mower, but no harm except for making a big mess. Two seals don't translate into a better seal! Always double-check it since then.
I guess I'm just **** but after the filter off I wipe everything down with a rag. So I'm sure if there was something left behind I would know something was not right.
they’re rated to within +/- 3%. At 22ft*lbs they’re well within spec.
These ain’t the cheap *** Chinese torque wrenches you get at Pepboys. Short of new Snap-Ons these SK torque wrenches are about as accurate as off the shelf torque wrenches can get.
Wow, how many of us have had that happen, ONCE?? I had it happen the first time I changed the oil on my (then) fiancee's '78 Honda Accord, WAAAYYY back in the day! Like y'all, it happened ONCE, and yeah, it made a mess! Ever since then I've always checked.
Some things need to be second nature. Making sure the old gasket came off with the old filter is one of them. Removing a fill plug before removing a drain plug also comes to mind. New to my list is ensuring the targa top is correctly reinstalled and secure before driving off.
Sometimes I scratch my head here.....I have been changing oil on a nyriad of cars for 45 yrs. And have never seen any instructions that dont specifically say to only hand tighten. I am guessing hand tight is about 20lbs. Make sure you always lube the gasket and hand tighten. Even just hand tightened some are very tight to remove. I have only had 2 filters with a problem. A Fram where the gasket adhesion failed and it slipped out of the crimp. I was warned by oil drips. The only other problem I had was a time I paid to have it done and some jamoc over tightened the filter. Using a proper oil filter wrench, 3 diff types only caused it to crush. In the end I had to drive a screwdriver through the filter and twist it off. Over all my years only the over tightened filter caused a problem, never the ones hand tightened per manufacturer reccomendation.
