Tow Hook
Old Apr 15, 2019 | 10:50 PM
Stan0324's Avatar
Stan0324
Default Tow Hook
I own a 15 Z51 that I installed a Z06 front grill on. The grill was purchased from Cultrag. The receiver on the grill has a metal plate over it. It appears that the grill has to be removed in order to expose the receiver.
A friend of mine also has a Z51 with a Z06 grill. He did not have the plate covering the receiver. Should this plate have been removed when the grill was installed or is my grill just not normal?
Old Apr 15, 2019 | 11:05 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Pics would help here. No Z06 grille I have ever seen had a plate covering where the tow hook installs.
Old Apr 16, 2019 | 04:59 AM
96GS#007's Avatar
96GS#007
Sounds like you’re looking where the blank is on the far passenger side. The receiver is 6” or so towards the center. If you’re looking in the right place, you need to post a pic. This is the only pic I have handy, but you can see where the tow hook mounts relative to the edge.
Old Apr 16, 2019 | 10:02 AM
Marcho Polo
Former Moderator
you mention a plate on the grille, there should be no plate on a Z06/GS grille.
Old Apr 16, 2019 | 12:28 PM
Stan0324's Avatar
Stan0324
Not a great picture but you can see the plate
Old Apr 16, 2019 | 12:44 PM
MCK_Z06's Avatar
MCK_Z06
Originally Posted by Stan0324
Attachment 48301938
Are you sure you have a 2015? I believe the 2014's did not have a receiver for a hook.
Yours looks like one of these without the receiver but, I cant exactly tell from the photo though because its not clear.
EDIT: I just saw where some of the early 2015 Z51's did not have them either.... (2015's built in 2014 did not have a receiver.)
Old Apr 16, 2019 | 01:04 PM
Stan0324's Avatar
Stan0324
Yes mine is an early 15.
Old Apr 16, 2019 | 01:30 PM
MCK_Z06's Avatar
MCK_Z06
You can get tow straps that attach to the jacking puck slots if you don't have a receiver. (Assuming you didn't just want the hook for looks.)
https://www.ebay.com/itm/30274267284...&ul_noapp=true
To Tow Hook
