Installing rear bumper
Old Apr 21, 2019 | 10:31 AM
36couper's Avatar
36couper
Default Installing rear bumper
I switched out my tail lights on my 2017 Z51.
Removing the bumper and switching them was simple.
However, I'm have a bear of a problem re-installing the bumper.
The drivers side clips in perfectly but I can't get the passenger side to line up and clip in.
Any suggestions?
Old Apr 21, 2019 | 10:50 AM
ricmalaz's Avatar
ricmalaz
The clips can move around enough that they won't line up when you try to re-install the bumper. Make sure they are positioned correctly.
Old Apr 21, 2019 | 03:13 PM
36couper's Avatar
36couper
Thanks! That was the problem. The clips were slightly moved.
Old Apr 21, 2019 | 10:39 PM
Glad you got it back together. How about a pic of what you swapped out - did you go to the Z06 clear lenses?
Old Apr 23, 2019 | 05:46 PM
dprestidge's Avatar
dprestidge
I just had mine off and had the problem with the passenger side. One of the red plastic clips was turned 90 degrees. Turned it and it went right on.
To Installing rear bumper
