Old May 2, 2019 | 06:02 PM
yellow2007's Avatar
yellow2007
Default 2015
I might be trading in my 07 yellow vert for a 2015 yellow vert. It has 60K miles on it which is a bit hi but heck, my C6 has 155K Are there any idiosyncrasies I should be on the lookout for at that mileage? I know the C6 had fuel sending unit and tranny cable issues....
Thank you all i advance......
Old May 2, 2019 | 06:15 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
A bit more info would be useful.
Z51 or not?
Which options?
Etc etc.....
Old May 2, 2019 | 06:28 PM
yellow2007's Avatar
yellow2007
Essentially a base vert.Non Z51
Old May 2, 2019 | 06:39 PM
KenHorse's Avatar
KenHorse
Synopsis - Even a base C7 is superior to a C6 in just about every way. (unless you're 6'4" and 300 pounds)
I assume from your post you're looking at an A8 and not M7?
Old May 2, 2019 | 06:54 PM
Mayor111's Avatar
Mayor111
Im not sure why anyone would think a 60k mile C7 is the same value as a C6 convertible with 155k miles... Looking at your Avatar, it looks like you have a base C6... Not sure how this trade is actually working for the C7 owner...no offense.
Old May 2, 2019 | 06:57 PM
KenHorse's Avatar
KenHorse
He said trading IN so I assume he's buying a used C7 through a dealer....
Old May 2, 2019 | 07:08 PM
dvilin's Avatar
dvilin
I had a 2015 Base M7 Convertible it had no problems the 3+ years I owned it and no known so called idiosyncrasies. I did not have 60k miles on it but I think you should be good the C7 is fine actually better than fine.
Old May 2, 2019 | 07:14 PM
Jmhornz71's Avatar
Jmhornz71
You shouldnt have any problems with the 2015. I bought my 2015 Coupe in Dec2017 with 51k miles. It now has 71k miles and runs like a top. enjoy it, it will run for a lot longer
Old May 2, 2019 | 07:22 PM
Stackenali's Avatar
Stackenali
If it's an A8 …..make sure it doesn't have the shudder issue. Also, C7's are prone to bent or cracked rims.
Old May 2, 2019 | 07:38 PM
Jeffer's Avatar
Jeffer
you probably know this but the yellow in 2015 is much brighter than the later racing yellow
so you will enjoy it
Old May 2, 2019 | 07:48 PM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
OP- If you get an A8, you better have some sort of warranty on the drive train.
Old May 2, 2019 | 08:12 PM
KenHorse's Avatar
KenHorse
Only Z's and GSs seem to have the issue, not Z51 or base cars....
Old May 2, 2019 | 08:27 PM
tta1415's Avatar
tta1415
I just traded in my 2015, it had the A8 shutter and I really wanted car play which 2015 doesn't have.
Old May 2, 2019 | 09:56 PM
Bavaria's Avatar
Bavaria
My 2015 M7 Night Race Blue 'base' Stingray is one of the most flawless cars I've ever owned in 60 years of car ownership. On a personal note, I believe it's profile is the sleekest looking Corvette available, without the spoilers, fenders, etc. If only my Lexus was as 'perfect'.
Old May 2, 2019 | 10:43 PM
As mentioned, the A8 has had some problems.
Old May 3, 2019 | 07:44 AM
plake's Avatar
plake
All the A8’s have potential shutter problems, model doesn’t matter. New fluids triple flushes and not sure the issue is fixed. The C8 won’t have this transmission I’m sure. A DCT and probably no manual.
Old May 3, 2019 | 09:50 AM
Dave02C5's Avatar
Dave02C5
Dont let the A8 shutter deter you. You can tune out the AFM and increase lockup pressure and it's good as new
To 2015
Old May 3, 2019 | 08:28 PM
iclick's Avatar
iclick
I would avoid a 2015 A8 for the aforementioned issues that IMO have not been resolved even in later YMs. You can dance around the problem with Range devices, shift only in manual mode, etc.--but neither was an acceptable fix for me. Also, the hatch is not powered in 2014-15 models and you will likely have difficulty closing it unless a door or window is at least partially opened. Mine simply would not latch with the cabin sealed up or by using a very forceful slam which may stress the hatch material over time. Later models had the power-down hatch, which fixed that problem. My fix for the above two issues was to buy a 2017 M7.
yellow2007's Avatar
yellow2007
correct
Old May 3, 2019 | 08:30 PM
yellow2007's Avatar
yellow2007
I'm not looking for an even swap. Just thinking of trading in and financing the C7
