Battery maintainer
Old May 4, 2019 | 02:49 PM
Larry P's Avatar
Larry P
Default Battery maintainer
I read somewhere plugging in the maintainer you should NOT plug in one end first.
Can't find it. Should I plug into the AC outlet first or the socket inside the hatch?
Larry
Old May 4, 2019 | 02:53 PM
vette48's Avatar
vette48
you first plug in the trunk and then into the 120 outlet. to remove unplug from 120 outlet then from the trunk. if this is the corvette charger, it should be on the tag on the cord.
Old May 4, 2019 | 03:07 PM
I agree with vette48. That is the way the instructions read with the GM maintainer I bought.
Old May 4, 2019 | 03:11 PM
Larry P's Avatar
Larry P
Thanks,
yes, I found the manual when I opened the box.
2015 and It has never been opened.
Larry
Old May 5, 2019 | 11:41 AM
wonka12_98's Avatar
wonka12_98
St. Jude Donor '16
I don't think it really matters. I've been doing it the opposite way for over 3 years with no problems!
Old May 5, 2019 | 12:34 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I leave my ctek plugged in to the wall and remove the connection from the car and drop it on the ground. When I park, I simply attach the magnetic connection and walk away. Been doing this from day 1 and no issues.
Elmer
Old May 5, 2019 | 01:42 PM
boxster99t's Avatar
boxster99t
Elmer
except for the magnetic connection part (unless CTEK changed, it's what I have and it's a watertight male into female quick disconnect).
Old May 5, 2019 | 02:08 PM
Larry P's Avatar
Larry P
I ended up plugging into a power strip with an on / off switch. I just turn it off and then unplug the connection inside the hatch.
I don't want to take a chance of the AC plug arcing plugging in or out.
Also, the manual clearly states to unplug the AC first.
Old May 5, 2019 | 02:15 PM
Null Pointer's Avatar
Null Pointer
Exception ID 10T
I have Ctek, Schumaker, and Black & Decker battery maintainers. The instructions for all of them say hook up to the car first, then plug in to the power source. Unplug from power source first before unhooking from the vehicle. I use them on cars and lawn tractors.
To Battery maintainer
