C7 ventilation
Old May 6, 2019 | 09:01 PM
Z06 Bill's Avatar
Z06 Bill
7th Gear
Default C7 ventilation
Although my car is a 2016 Z06 convertible, I suspect this question applies to all C7 cars. I bought the car new three years ago. When running the heater/ventilation controls set to "Vent" and "Lo" temperature (A/C off), the air coming from the vents is hot. The A/C works fine, but ventilation air temp control is non-existent. I mentioned this twice to the selling dealer, and was told it is normal because the air inlet is underhood. I'd forgotten about it until I took the car for a "first ride" of the season. About 65 degrees outdoors, and with the top up and HVAC set to "vent", as soon as water temp was normal the hot air flowed through the vents.
Has anyone else experienced this, or have any advice? Thanks.
Bill B
Old May 6, 2019 | 11:22 PM
Yes, the air is warm under those circumstances in my car too.
Old May 7, 2019 | 01:28 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by Z06 Bill
Although my car is a 2016 Z06 convertible, I suspect this question applies to all C7 cars. ...
I never use vent, AC always on auto. It keeps temp set. But I have a coupe so no wasted air or heat as never have the top off!
Old May 7, 2019 | 08:47 AM
bjones7131's Avatar
bjones7131
True with all vehicles, I have a 1993 S10 and when on vent air is warm when engine heats up.
Old May 7, 2019 | 09:47 AM
Frosty's Avatar
Frosty
I always have it on recirculate
Old May 7, 2019 | 10:21 AM
Maxpowers's Avatar
Maxpowers
Keep in mind how close the LT1 is to the HVAC system, and our firewall isn't exactly built for luxury and comfort.
Old May 7, 2019 | 09:42 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
My vents are hot without the compressor on regardless of how low the temp setting is...
Old May 7, 2019 | 10:00 PM
Jmhornz71's Avatar
Jmhornz71
I have that problem too. When the Ac is off I will not put it on vent as the air is pretty warm. If I have the roof on and the windows up even though its not to hot out I will turn the ac on and set about 70 or so just to keep it comfortable I wish there would be some way to bring in cool outside air into the car without opening the windows
Old May 8, 2019 | 06:58 AM
Former USMC's Avatar
Former USMC
Bill B
Bill,
I too have the exact same problem. Even with temps around low 60's, the vent (no AC on, temp set LO) still blows hot air. I guess the best solution is to keep the AC on and adjust the temperature accordingly.
Semper Fi
Old May 8, 2019 | 12:54 PM
Rebel Yell's Avatar
Rebel Yell
Yep, as the old saying goes "they'll do that". The air heats up as it goes through the engine compartment. My vert is the same.
Old May 8, 2019 | 07:48 PM
pnsnkr's Avatar
pnsnkr
Although my car is a 2016 Z06 convertible [...]The A/C works fine, but ventilation air temp control is non-existent.
Bill B
The ventilation in my 'vert works quite well. All it takes is one push of a button and the cabin is ventilated...
To C7 ventilation
