TPMS problem
Old May 12, 2019 | 02:26 PM
lifter213's Avatar
lifter213
Default TPMS problem
I got some some new wheels and bought all new GM pn: 13598775 sensors and had everything mounted and balanced etc from Discount Tire and took them home. After I put the new wheels on everything was cool, the new sensors were detected instantly.
I’ve had a few hundred miles on the new wheels/sensors now and last night the Front passenger side went out. Not giving any reading at all. The tire does have the proper tire pressure after manually checking.
Hoping someone might have a tip to get this one sensor working again so I can avoid buying another one and most importantly having that tire removed etc
FYI It’s a 2016 Stingray
Old May 12, 2019 | 02:29 PM
Bill Dearborn's Avatar
Bill Dearborn
Sounds like you have a failed sensor, It could have been damaged during the installation process.
Bill
Old May 12, 2019 | 10:09 PM
Yeah, possible that it was damaged during the install or could just be a defective sensor.
To TPMS problem
