Tire storage solutions
Old May 13, 2019 | 03:28 PM
VENOM ACR's Avatar
VENOM ACR
Default Tire storage solutions
Hey everyone
Just wondering how people are storing extra tires in their garage. I saw Amazon had some wall mountable tire storage racks but they look suspect. Wondering if anyone came up with something on their own or bought something. Damn GS tires are so big it's taking up a lot of garage floor space so would definitely like to get them up and out of the way.
Pictures are much appreciated. Thanks!
Popular Reply
May 14, 2019, 07:35 AM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
I stacked my original wheels and tires off my '99 and made a bar height table. I mounted some low profile casters to a piece of plywood so it can be moved. I also bought and finished a round table top for the top. It solved my problem hope it helps with yours.
Old May 13, 2019 | 07:02 PM
Widgeon5's Avatar
Widgeon5
Originally Posted by nikeair042
Hey everyone
A really good one is available from (surprise, surprise) Tire Rack. Link: https://www.tirerack.com/accessories/detail.jsp?ID=164. I haven't tried it with Corvette tires, but doing the math, the nominal ZO6 widths total out to just under 49 inches. The rack can accommodate 52 inches. Now the best use of a rack like this is to mount it high enough to walk underneath. Mine is some 8 feet up, which requires a simple block and tackle rig and a ladder to get them up and down. A bit of an ordeal, but I only switch out the tires twice a year.
Old May 13, 2019 | 10:33 PM
When I had extra wheels/tires for my C5, I put down a thick piece of old carpet on the garage floor then stacked the wheels/tires on top of each other with a piece of cardboard in between each one. Worked well for me.
The rack you can mount to wall studs seems like it would work well too.
Old May 13, 2019 | 10:47 PM
Silver C7's Avatar
Silver C7
I stack mine on a covered pallet. Works fine.
Old May 14, 2019 | 07:35 AM
JohnnyDee's Avatar
JohnnyDee
Old May 14, 2019 | 08:02 AM
UsernameProtected's Avatar
UsernameProtected
I gave up and bought another rental property. This one is two minutes from my home, and has a detached 2 1/2 car garage behind it (and seven acres). I rent the house out and keep the garage for my personal use. It's not a big money maker, but how many tire storage solutions pay you $3,500/year?
Old May 14, 2019 | 08:08 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I placed my OEM wheels and Cup Tires in the Forgeline shipping boxes and stacked them in the corner of the garage.
Old May 14, 2019 | 08:11 AM
ddrag1's Avatar
ddrag1
Because of a lack of space in my garage, I needed to hang my tires flat against the wall. I used a some heavy duty shelf brackets that I purchased from my local big box building supply store. I flipped the bracket so that the long side is mounted on the wall. When used for shelving, I believe that the long side is usually used to support the shelf and the short side is bolted to the wall. I mounted the bracket with lag screws directly into the studs. Then, I split some heater hose and put it on the top of the bracket to prevent scratching my wheels. I think there was a sticker on the bracket indicating that they were good for 600 pounds. For the 4 brackets, lag screws, washers and heater hose, I think I spent about $35.
Old May 14, 2019 | 09:32 AM
Maxpowers's Avatar
Maxpowers
This is what I do:
Old May 14, 2019 | 11:20 AM
Akcajunz's Avatar
Akcajunz
Veteran: Coast Guard
This is an awesome idea! I'm still on my factory tires, but I'm going to steal this idea when its time for new tires. Thanks!
Old May 17, 2019 | 03:18 PM
VENOM ACR's Avatar
VENOM ACR
Very good idea!I dont have a spare set of wheels yet, so just the tires for now. But this is a much cheaper alternative. I found some racks but they were a couple hundred. Thanks for the picture and idea!
Old May 17, 2019 | 03:56 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Hey everyone
My bedroom, next to my drum set.....cool and dark.
Old May 17, 2019 | 04:51 PM
V Vette's Avatar
V Vette
Originally Posted by Maxpowers
This is what I do:
Com on man! Can you give it one coat of paint on walls!!!!!
Old May 17, 2019 | 09:11 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Thinking a bit outside the box (garage)...
We have a hillside ranch house with a walkout basement and sliding glass doors, plus an unfinished area that we use for junk storage.
Being lazy and not having a lift, I let the dealer swap between our summer PSS and winter AS. Since they flush the brake fluid once a year, that swap costs me nothing extra. The other time, about $25.
After they do the swap, they load the removed wheels/tires into our beater. I drive 15 minutes home and around the back of the house. Roll the tires out of the car, across a throw rug that's flipped upside down to protect the good carpet, and into the storage area. There's a big trash bag & piece of cardboard on the concrete floor, stack the tires with cardboard in between.
The storage area is cool/dry/dark. Temperature never gets above 75' or below 55'. No worry about the 20' limit on the PSS.
This won't work for everyone, but works for me. Life is good.
Old May 17, 2019 | 09:17 PM
Mister Big's Avatar
Mister Big
Brilliant, just brilliant.
Old May 18, 2019 | 10:54 AM
Maxpowers's Avatar
Maxpowers
LOL. Dude, on my long list of "to do's", that is like number 50.
Old May 19, 2019 | 10:09 AM
Mike1320's Avatar
Mike1320
On a furniture dolly under a moving blanket in the back of the third garage. Not elegant but effective.
To Tire storage solutions
Old May 20, 2019 | 10:24 AM
Fagunza's Avatar
Fagunza
Default My tire rack
This will hold three sets of tires.
https://www.uline.com/Product/Detail...E&gclsrc=aw.ds
Old May 20, 2019 | 10:30 AM
1SG_Ret's Avatar
1SG_Ret
I kinda like this one.
https://www.griotsgarage.com/product...ks&from=Search
Saves on the old back.
Old May 20, 2019 | 04:11 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
I think I would use some left over lumber and build a rack before spending 140 plus shipping on a rack.
But mine are stacked on the garage floor, wrapped in garbage bags (to keep me from getting things dirty with them, not really for protection) and pieces of cardboard between them. The large 20" rims stick out a bit and will touch the floor, so make sure they are not the bottom.
