Lights stay on
Lights stay on
All of my interior lights stay on. I have searched the manual but cannot seem to locate a solution. This just started today on the way home from shopping. Per the manual the lights shut off after 10 minutes to save the battery. It is a 2017.
Thanks,
Evan
Thanks,
Evan
Moderator
It sounds like you have "turned on" the interior lights. This is done by turning the Instrument Panel Illumination control complete clockwise. Turn the know counterclockwise.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,862 Likes
2015 C7 of the Year Finalist
Did you turn up the dash light and make them brighter? If you go past a certain point, you turn on the interior lights as Zymurgy mentioned. Fiddle around with the **** and stop just before the interior lights come on.
Elmer
Courtesy Lamps
When any door or the rear
compartment is opened, the interior
lamps will come on.
The rear compartment lights only
come on when the rear
compartment is opened.
To turn the courtesy lamps on or off,
turn the instrument panel brightness
**** completely clockwise or
counterclockwise.
lamps will come on.
counterclockwise.
