Performance mode
May 15, 2019 | 05:02 PM
Performance mode
i recently bought a 2016 z51 and i don'at see the perfomance mode does it come in all z51 models
May 15, 2019 | 05:04 PM
I think you have to hold the traction control button down for a few seconds until the mode shows up in the DIC.
May 15, 2019 | 05:27 PM
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Yes it comes in all Z51 models.
May 15, 2019 | 07:39 PM
Put the car in Track Mode and push the center button twice quickly on the mode selector. It's covered in the OM
May 15, 2019 | 09:01 PM
Quote:
Originally Posted by
Jrobinson870
I did that it says competitive mode not performance
May 15, 2019 | 09:03 PM
If you are in Track Mode it should go into performance traction mode. Are you certain you have the Z 51 package?
May 15, 2019 | 09:05 PM
TNSQUIRE
If this isn’t what your looking for I’m at a loss. I know there is a performance shifting mode with the autos. However I’m unsure if there is any message about it.
May 15, 2019 | 09:07 PM
Jrobinson870
Yes it says it's the Z51 PACKAGE. IT HAS THE SLOTTED BRAKES AND 20 INCHE REAR WHEELS
May 15, 2019 | 09:11 PM
saleen556
Just watch the video and did some research it says that the performance mode is in the Magnetic Ride package
May 15, 2019 | 09:12 PM
May 15, 2019 | 09:18 PM
Jrobinson870
Yes you need to have the dial behind the shifter to change modes. Not sure if that’s standard with Z51 option.
May 15, 2019 | 09:26 PM
TNSQUIRE
May 15, 2019 | 09:38 PM
May 15, 2019 | 11:05 PM
PTM is only available if your Z51 has Mag Ride (FE4).
May 15, 2019 | 11:06 PM
saleen556
All C7's have the Mode dial.
May 15, 2019 | 11:13 PM
C7 of Year Finalist (track prepared) 2019
Zymurgy
This is the answer. The z51 can be had without the magnetic shocks. The mag ride is what you need for performance traction managment (PTM).
If you don't have magnetic shocks, it will go into competitive mode like you are describing.
May 15, 2019 | 11:32 PM
Zymurgy
Learn something everyday 😄
May 16, 2019 | 12:51 AM
I tried to use the Performance traction management on my 2016 Stingray with mag ride (non Z51)
I cannot get it either, just says competitive mode.
But my Mag ride is code FE2, not FE4. is there a difference? Is this why I dont have it?
-Dan
May 16, 2019 | 01:12 AM
Since the
Manua l specifically reads "...FE4," Dan, I'd say so.
