What is this missing tool
Old May 19, 2019 | 01:35 PM
tjdismee's Avatar
tjdismee
Default What is this missing tool
Just bought a 2104 Z51. What is this missing tool?
Old May 19, 2019 | 01:42 PM
gpuglisi's Avatar
gpuglisi
Tow hook. It's not missing, not included with the car. Also, with a 2014 you don't have a threaded receiver for it.
Nordic_Samurai's Avatar
Nordic_Samurai
Holder for a tow hook.
Old May 19, 2019 | 01:44 PM
Quietbreaker's Avatar
Quietbreaker
Which model years are supposed to have these? I had this foam piece knocking around in the trunk of my '15 when I bought it also.
Old May 19, 2019 | 02:03 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
It is in the cars that go overseas. I don't think the US cars get the tow hook.
Elmer
Old May 19, 2019 | 02:56 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Not quite. My understanding is that the Z51 has the receiver but the base car doesn't
Old May 19, 2019 | 03:12 PM
owc6's Avatar
owc6
No U.S. '14 has the threaded reciever
Old May 19, 2019 | 03:13 PM
Quietbreaker
Does anyone know where this foam piece is even supposed to sit? It was just rattling around in the storage area when I got the car.
Old May 19, 2019 | 03:22 PM
owc6's Avatar
owc6
It covers the battery in the rear under the carpet.
Old May 19, 2019 | 09:23 PM
I got curious today and checked my 2014 for a tow hook receptacle. None to be found.
Old May 20, 2019 | 12:14 AM
orca1946's Avatar
orca1946
tow hook and it cost about $ 100 -125 to buy one!!
Old May 20, 2019 | 09:34 AM
eboggs_jkvl
Moderator emeritus
...aaaaaaaand you have a removeable panel right where a tow hook would go IF YOU had a hook receptacle! You also have a hole where the PDR camera would have gone had we the option to get that item. The 14s missed out on tow hook, PDR, A8, and front cameras.
Elmer
Old May 20, 2019 | 01:33 PM
Zymurgy's Avatar
Zymurgy
Moderator
Correction, 2015-2019 missed out on the A6. LOL.
Old May 20, 2019 | 01:57 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
The 2014 and I think 2015 Z51 did not have the receiver. The Z06 and my 2017 GS have receivers. This is a pic of one I bought from forum vendor http://wwwzl1addons.com
Better than the cheep GM simple "eye hook," for ~ the same price.
ONLY INSTALLED FOR CAR SHOW. Doesn't fit in foam battery cover recess but fits fine in rear cubby.
Old May 20, 2019 | 02:15 PM
eboggs_jkvl
Moderator emeritus
That is another "good" thing too!
Elmer
Old May 20, 2019 | 05:24 PM
Avanti's Avatar
Avanti
With a "2104" I suspect you can just press the levitate button if you need it moved during track days... if the GM produced button happens to be working that day.
Old May 20, 2019 | 05:26 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Europe Only.. I store my Additive funnel there
To What is this missing tool
Old May 20, 2019 | 06:22 PM
CourtneyJudd's Avatar
CourtneyJudd
my 2014 Z51 has that in the trunk over the battery and it has a funnel in it.... my guess for oil fill or gas tank
Old May 20, 2019 | 07:09 PM
JerryU's Avatar
JerryU
Yep it's for adding things like Techron. It holds the gas filler flap open. But I store mine I the rear compartment.
Good chance of ripping the carpet every time you have to pull that unbound section of carpet from under the plastic wheel well cover! In fact when I need to get the carpet out, to access battery or rear fuse panel, I pop off the bottom clips and pull the bottom of the plastic wheel well cover off first! Bottom clips are 3 inches up from the carpet and it pops back in with the side of your hand.
NOTE WOOD IS JUST FOR TAKING PIC. CAN PULL PLASTIC FROM CLIP WITH FINGERS. THEN HOLD PLASTIC OUT WHILE REMOVING UNBOUND CARPET.
Old May 20, 2019 | 11:03 PM
Deepdiver's Avatar
Deepdiver
2015 Z51's have the receiver
