Mobil 1 oil cap available for the wet sump cars
Is there even a Mobil 1 oil cap available at all for the wet sump cars?
5w30 or 0w40
Anyone have a part number for either one?
5w30 or 0w40
They do as I put one on my last ride and my new Z51
https://www.corvetteblogger.com/2018...w-40-oil-caps/
The official GM part numbers for the new oil caps are:
https://www.gmpartsgiant.com/parts/g...-12686472.html
- 12686472 – 2019 Corvette Stingray w/o Z51
- 12680708 – 2019 Corvette Stingray w/Z51, Grand Sport, Z06, ZR1
You should be able to get the cap from the dealer as well. My 2019 Stingray came with one. You should also be able to get the sticker from the dealer as well. It was in my owner's packet.
cowboy casey (05-23-2019)
twowinns (05-24-2019)
Question: Did the 0W-40 oil start for the 2019 models? My owners manual for my 2016 Stingray Z51 A8 says to use 5W-30 and it also has the oil cap that says 5W-30 as well.
MT
MT
Received 3,439 Likes
Thank you for posting that!
You are sincerely appreciated!
Called the dealer. Interesting that the dry dump one is $31 and the non-dry sump one is only $8.
Or you can keep using the 5W-30. There are tons of threads around here discussing this if you want to go down the oil wormhole.
OK...you got the cap now
Where the hell do you get the oil.... for less than $10/quart
I've seen it in Wal-Mart for $9.38
I DIY oil change on a Dry Sump version costs about $100
BostonVette (06-25-2019)
The rebate link is on the summit site at the oil page.
You can either submit it on-line or print a version and snail it in.
Either way you'll need the paid receipt
Here is a link to the page:
https://www.summitracing.com/parts/mob-123875
Details on the rebate and the link are above "Add to Cart"
Received 5,217 Likes
My '18 came with a 5W-30.
