Z51 octane
Back to the Indy 500. Pace Car - C7 driven by Earnhardt, Jr.
pg 212
"Recommended Fuel
(LT1 6.2L V8 Engine)
Do not use any fuel labeled E85 or
FlexFuel. Do not use gasoline with
ethanol levels greater than 15% by
volume.
Premium unleaded gasoline
meeting ASTM specification D4814
with a posted octane rating of 93 is
highly recommended for best
performance and fuel economy.
Unleaded gasoline with an octane
rated as low as 87 can be used.
Using unleaded gasoline rated
below 93 octane, however, will lead
to reduced acceleration and fuel
economy. If knocking occurs, use a
gasoline rated at 93 octane as soon
as possible, otherwise, the engine
could be damaged. If heavy
knocking is heard when using
gasoline with a 93 octane rating, the
engine needs service."
Why would I not want the very best out of my car? But, the real question here was about octane at altitude. I'm at 5280 feet (you know, Mile High City). The word "altitude" does not appear anywhere in the 367 pages of my owners manual. So, I was reaching out to those with altitude experience, tuning older vehicles, etc.
So, I beg to differ sir. It does not have complete instructions, it was written for sea level cars.
I'm your Huckleberry. :-)
I can only answer half your question. Maybe somebody else can answer the other half. The half I know is that once a turbo or super charger reaches what’s called critical altitude, the turbocharger waste gate or supercharger internal bypass is fully closed at full throttle, meaning it’s putting up as much boost as it can, and further increases in altitude will cause MAP (manifold absolute pressure), power, and octane requirement to fall off just like a normal engine. Turbo or super charged airplane engines have a ton of fat built in, so their critical altitude is usually in the 20,000-30,000 foot range, and they require full octane until they get above that altitude. A car obviously wouldn’t have anywhere near that much fat, but I don’t know whether the Z51 supercharger’s full throttle MAP starts dropping off right away like a regular engine, or whether it has a bit of fat that would let it maintain full throttle MAP up to a few thousand feet. If there’s little or no fat, the lower octane gas in Denver should be ok. But if the Z51 supercharger has a bit of fat, it may not be.
One last warning. If you can’t find a spec sheet with full throttle MAP versus altitude, it can be confusing to try to figure it out by testing with your car. It’s MAP that matters for octane requirement and power, not boost, and the gauge on your car’s instrument panel is probably boost. MAP is absolute pressure while boost normally means differential pressure above the atmospheric pressure where you are. Atmospheric pressure in Houston at sea level is about 15psi, while in Denver it’s about 12psi. MAP is equal to that pressure plus boost. So let’s say you run a full throttle test in Denver and another in Houston, and you get 15psi boost in both places. In that case, the Houston MAP would be 30psi while Denver MAP is only 27psi. That would indicate that the Z51 supercharger has little or no fat, and using lower octane gas in Denver is ok. But if the Houston full throttle boost is 15psi and the Denver boost is 18psi, then both MAP’s would be 30psi. That would indicate there is fat in the Z51 supercharger, and you are potentially in trouble using lower octane gas in Denver.
If the OP is indeed talking about the normally aspirated engine, then he should be ok with lower octane gas at high altitude. The reason it’s ok is that engine power and octane requirement are related to MAP, not throttle opening, and with a normally aspirated engine, MAP can never be higher than the atmospheric pressure at your location, which in Denver is only about 12psi versus about 15psi at sea level. So when you floor it in Denver, your MAP is only about 12psi. If you floored it in Houston, your MAP would be about 15psi. To get a MAP of 12psi in Houston, your gas pedal would only be about 80% of the way to the floor. So if you were living in Houston and never pushed the throttle any more than 80% of the way to the floor, you wouldn’t need max octane either.
On the second count, I apologize for opening a new thread. Perhaps I'm just not adept with this search engine. I tried "octane' and got 496 hits. Perusing through a bunch, I couldn't find anything pertinent, so I tried again with with "octane and altitude". The engine said it threw away extraneous words.
Regards
No need to be sorry - you had a not-unreasonable question and got an answer. Besides, reopening an old thread is sometimes frowned upon - depends on some unwritten rule regarding age of thread, pertinence to current issue, and phase of the moon.
Welcome to the Forum.
Regards
My question is, what changes to the motor were made in 2019 that require 93 (per OM)? I can see the Z06/ZR1 (LT4/LT5), but for us on NA LT1?
I was at a remote location the other day and all they had was 90. The car seems to run fine but I'll be sure to fill up with 91 = at next fill up.
