Clicking noise from rear passenger wheel...need help!
I have a clicking type noise from the passenger side that seems like its coming from the rear passenger wheel area. First thought it has a rock stuck in my tire tread but it wasn't consistent with each tire rotation. I am dumb founded at what it could be. With windows shut and radio on you can't hear it but with windows down it is much loader. so definitely coming from outside the car. Doesn't happen all the time which is confusing. Mostly on INITIAL acceleration or gear change but at different speeds and not ALL the time. I have a '19 GS A8. Any thoughts?? THANK YOU!
Vette_17 (05-30-2019)
Received 5,218 Likes
I've had loose rear axle-nuts on my C5 retightened twice in 18 years, last time about 2 years ago. Someplace to start.
shot a video of the clicking noise. tried to reproduce it the best i could. you can hear it better on the second time i go in reverse.
Vette_17 (06-04-2019)
Video of rear passenger wheel well 'Clicking'...
Had a few minutes to shoot a video of the 'clicking' noise present at the rear passenger wheel well. My neighbor has the same exact car, '19 GS A8 and his car doesn't have the clicking so its not characteristic of the car. Anyway hope the video plays (i stink at this stuff). Any thoughts on the noise? You can hear it better the second time i put the car in reverse.
Moderator
Merged your video thread into your previous thread on the subject.
I had the same problem. Mine was evident when loading the gear train going from forward to reverse and reverse to forward. Loose axle nuts was the problem per Chevy, replaced and torqued fixed the issue.
Z51VetteFan (08-18-2019)
All I know is that I had the dealer look at mine, when I took it in for an oil change. They found the axle nut loose and retorqued it. They also stated that if the issue continues, to replace the axle nut.
