What am I doing wrong?
Old May 27, 2019 | 12:25 PM
Bsull's Avatar
Bsull
Default What am I doing wrong?
While trying to learn my new GS, I attempted to open the trunk with the metal key. Owners manual says to put the key in the slot near rear license plate and turn to open the trunk. Did that, clicking noise from gas door, no other indication the key was being turned. Anybody know what I'm doing wrong?
Old May 27, 2019 | 12:35 PM
joemessman's Avatar
joemessman
It's pretty straight forward. If it is not working you are not applying enough pressure when turning, or it is defective and need to visit the service department.
Old May 27, 2019 | 12:36 PM
SingleTrackMinded's Avatar
SingleTrackMinded
I have not used the key, but right next to the keyhole is a rubber electric switch that you can open the trunk by simply tapping/pressing - but you likely already knew that.
Old May 27, 2019 | 01:05 PM
Bsull's Avatar
Bsull
I turned the key in both directions with quite a bit of force. In one direction it would only move about 1/8th of an inch, in the other direction it turned a good quarter turn then stopped, that's the direction I heard the gas door click. I'm familiar with the operation, same as my C6. It's going to the dealer tomorrow morning to finish some post purchase issues, so I'll bring it up then.
Thanks for the suggestion, I'm familiar with the rubber covered button. That is how I usually open the trunk. My issue is I was trying to learn the car and make sure everything I paid for works. I will mention this to the dealer tomorrow.
Old May 27, 2019 | 01:25 PM
Maxpowers's Avatar
Maxpowers
There have been some folks reporting that there manual keys aren't working. Good to get ahead of this with the dealer under warranty.
Old May 27, 2019 | 01:27 PM
RonC7's Avatar
RonC7
It does take some force to open. A quarter turn or so is correct. It is also possible that the cable is disconnected / never connected.
Old May 27, 2019 | 07:12 PM
Yaupon's Avatar
Yaupon
Just checked...exactly 1/4 turn with key and the trunk opened. 2017 base stingray coupe. Hope this helps.
Old May 27, 2019 | 07:19 PM
Internets_Ninja's Avatar
Internets_Ninja
It also could be the wrong physical key. If you arent the original owner, the previous owner may have replaced the key fob with a used one from another car and the actual key is incorrect. Do you have a second fob and have you tried that key?
Old May 27, 2019 | 07:29 PM
Bsull's Avatar
Bsull
I'm the original owner. It's a 2019 GS convertible, just at 600 miles. Since it's going back to the dealer again to finish up a couple of pre-purchase items I thought I would go over as much of the car as I can.
I'm going to start another thread about this car and the trials and tribulations of getting it in satisfactory condition after I get it in satisfactory condition. It is turning out to be more aggravating than I thought. For a really expensive car, at least for me, I didn't find the manufacturing quality or the dealer quality to be what I expected. But that's for another another thread.
Old May 27, 2019 | 07:30 PM
Bsull's Avatar
Bsull
thanks for the verification.
Old May 27, 2019 | 07:59 PM
joemessman's Avatar
joemessman
That's very true.
Old May 27, 2019 | 10:21 PM
Hope you get it fixed/figured out and luckily you have a warranty to fall back on if it comes to that.
Old May 27, 2019 | 10:44 PM
owc6's Avatar
owc6
It is a harder and tougher turn than anyone would expect.
Turn the key counterclockwise hard and far.
Old May 28, 2019 | 08:15 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
I was the original owner of a 2013 GS convertible and after I took delivery I was checking all of the functions at home and discovered that the trunk lock would no open with the key. Took it to the dealer and they cut another key based on the VIN and found out that didn't work either. Turns out that the lock cylinder installed at the assembly plant didn't match the VIN. The dealer installed a new lock and key set.
Old May 28, 2019 | 09:02 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
http://www.jaxvette.com/boggs/IMG_1435.MOV
Elmer
Old May 28, 2019 | 09:03 AM
eboggs_jkvl
Moderator emeritus
Actually, it would be clockwise. It turns to the right as you look up at the key. Same direction as tightening a screw.
Elmer
Old May 28, 2019 | 09:51 AM
owc6's Avatar
owc6
Elmer
You are correct, I am also correct.
I was looking at it from the top. Your description about a screw is better. I'll have to start using that.
To What am I doing wrong?
Old May 28, 2019 | 10:38 AM
eboggs_jkvl
Moderator emeritus
Old person pespective...
Again, we are screwing the same way now!
ELmer
Old May 28, 2019 | 11:35 AM
Ghostnotes's Avatar
Ghostnotes
Hell mine does not even have the key access
Old May 28, 2019 | 11:50 AM
eboggs_jkvl
Moderator emeritus
You're C7 doesn't have the key hole? Me thinks yer playin' with words.
Elmer
