M7 clutch Fluid
Old May 27, 2019 | 02:27 PM
kaplana08's Avatar
kaplana08
Default M7 clutch Fluid
Anyone notice that the clutch fluid in the C7 stays much more cleaner than the C6. Each time I use the ranger method I notice 3 or 4 times does it. Fluid is always pretty clean or light in colored coming out of the reservoir the first time.I just bought a new 16 oz. bottle of GM Dot 4 Brake and Clutch fluid and have a load left over. can it keep with the cap tight on ?
Old May 27, 2019 | 03:38 PM
Kracka's Avatar
Kracka
I wouldn't since it'll absorb moisture from the air in the bottle. A few months maybe, but I wouldn't use it much beyond that.
Old May 27, 2019 | 04:25 PM
Red86Cfour's Avatar
Red86Cfour
As long as you use it for the clutch it will be ok. I wouldn't use it for brakes. Just change out a few reservoirs full every couple of months and when you change oil.
To M7 clutch Fluid
