C7 air conditioning issues
Old May 28, 2019 | 08:25 PM
millers1's Avatar
millers1
Default C7 air conditioning issues
2014 C7 Z51
End of last season AC would operate intermittently. Had it checked in October when it went in for inspection. Tech heard of the issue before but had no answers. Everything checked out ok, still no AC. From the beginning of this season no AC at all.
The service department hasn't been able to shed any lite on the issue. Any body else have this kind of issue?? Seams like the computer isn't pulling in the compressor?
Old May 28, 2019 | 08:31 PM
runner61627's Avatar
runner61627
Irrespective of whether anyone else has had the problem, it’s time for a “second opinion” from another dealer’s service department.
Old May 28, 2019 | 09:32 PM
RonC7's Avatar
RonC7
Does the A/C compressor clutch engage?
There is both a fuse and relay in the under hood fuse box that control the A/C clutch. Of course, low refrigerant pressure will short cycle the compressor or prevent clutch from engaging.
I had a stuck relay on another older car. I just swapped it for an identical relay - clutch engaged, then swapped relays back and all continued to work.
GL
Ron
Old May 28, 2019 | 09:35 PM
Rangerdog1's Avatar
Rangerdog1
Is the blower fan not working or is the AC unit not operating? Had my blower fan stop once.
Old May 28, 2019 | 09:42 PM
Ron'sGS's Avatar
Ron'sGS
Exactly, go to another dealer. If they can’t figured it out, or have any suggestions on what’s going on I wouldn’t be taking my car there.
Old May 28, 2019 | 10:10 PM
Rangerdog1's Avatar
Rangerdog1
I found this post by...RobBeacon; .
. If your fuses aren't blown I would recommend unplugging an plugging the motor back in. For whatever reason this worked for me. I actually pulled the entire assemble out removed the cover on the blower motor and tested the capacitors on the board they all had some voltage in them and nothing looked burnt. I then checked for voltage at the wire and sure enough it was there. plugged it back in and it started working. No idea why this would work but it did so before wrestling with those 5.5mm bolts I would try removing plug and plugging back in.
I didn't copy all of his post.
Blower motor is located under the passenger side dash there are 3 plastic screw fasteners holding the cover on.
Hope this helps
Old May 28, 2019 | 11:15 PM
owc6's Avatar
owc6
My blower motor fused. The compressor was still working but no fan.
Old May 28, 2019 | 11:38 PM
RonC7's Avatar
RonC7
The OP says no A/C or intermittent A/C but does not say no heat or air flow. He questions compressor operation - so likely not a blower issue, but a lack of cold air. Most likely a compressor, fuse, relay, diverter door or controls issue. There was one recent case where the owner just had to cycle through various modes and the diverter door apparently started working.
Ron
Old May 28, 2019 | 11:47 PM
Rangerdog1's Avatar
Rangerdog1
Removing the electrical plug at the fan blower motor and reconnecting the electrical connector my fan started working and I have not had an issue with it since. The fan blower motor has a built in resistor at the connector that may have been shorted and is replaceable, it's tight quarters but doable and a diy project.
Old May 29, 2019 | 11:08 AM
Landru's Avatar
Landru
Didn't say whether there's an extended warranty.
This really isn't for a dealer anyway, especially if out-of-warranty.
A shop specializing in AC is, hopefully local area has one.
If so take it there, they'd have it diagnosed quickly & repair whatever for <$ than any dealer.
Which assumes dealer's are capable of even ID'g issue.
Old May 30, 2019 | 08:56 PM
millers1's Avatar
millers1
Thanks for all the input, I think we'll try a different dealer.
Old May 30, 2019 | 09:09 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Low probability, but check the electrical connector on the compressor itself. My 2015 had intermittent a/c shortly after delivery that eventually quit altogether. Dealer found that connector not fully seated, probably an assembly line error.
Old May 31, 2019 | 08:24 AM
Frosty's Avatar
Frosty
My car is in the dealership right now to have the A/C compressor replaced and I thought it was just a faulty pressure relief valve as I had good cooling. Only 2K miles. See my other recent post.
Anything to do with A/C, I recommend the dealership. If it requires a major component replacement, e.g. the compressor, they have to drop the front engine cradle which is 8 hours of labor. I wouldn't want an independent A/C shop doing that as someone else suggested. Plus components are not typically stocked and have to be shipped which takes three days as GM did not pay the extra Fedex shipping cost to over-night my compressor.
Old Aug 20, 2020 | 08:50 PM
Juan gutierrez's Avatar
Juan gutierrez
1st Gear
Hope this helps
Thank you this really help the plug was lose..
Old Mar 28, 2023 | 06:33 PM
StealthC7's Avatar
StealthC7
1st Gear
Hope this helps
Do you have to unplug the battery for this?
Old Feb 8, 2024 | 01:07 PM
HotBlondePinkVette's Avatar
HotBlondePinkVette
7th Gear
Default C7 hvac not working
Ron
Hi,
I have been scouring YouTube and this forum trying to find an answer to a similar issue. over the summer, I left the top off my car and it had some rain get inside. As soon as I realized it was raining, of course wiped it all up, but then I started having issues. The entire infotainment center was not lighting up and I was unable to use any music Bluetooth cigarette later heating, etc. I’ve searched the Internet. I’ve disconnected reconnected the battery, checked the fuses and pulled most of them and put them back in in the trunk and in the hood I got Music Bluetooth and the cigarette plug thing to start working again after popping off some of the dash trim near the driver side foot well or under the seat wiring harness is somehow how I got music Bluetooth, charging adapter etc.working again.
I still have no heat or AC. The display buttons are not illuminated. And when I attempt to push the various HVAC control buttons (not dials), it will change the song that I have playing. Any suggestions or ideas? I hope I gave enough information. Thank you for your help!!
Old May 8, 2026 | 01:19 PM
mgood's Avatar
mgood
Hope this helps
Thanks to this old thread, I fixed my air conditioner on my lunch break 😋
Plug for the blower motor. I got to it and was trying to figure out how to unplug it. Before I got it out, I started the car to see if wiggling it had done any good. Blowing strong. I pushed on the plug to make sure it was in there good and put the cover back on.
To C7 air conditioning issues
