Headlight lens
Old May 30, 2019 | 07:59 PM
Rhettvette's Avatar
Rhettvette
Default Headlight lens
Does anyone make a replacement lens for the headlights yet??
Old May 31, 2019 | 03:13 PM
Maxpowers's Avatar
Maxpowers
I saw a video of someone taking the C7 headlight a part. Its an integrated unit and parts cannot be taken off. He had to use a dremel to cut the lens off and then glue it back on.
Old May 31, 2019 | 03:17 PM
TNSQUIRE's Avatar
TNSQUIRE
It's a sealed unit.
Old May 31, 2019 | 03:37 PM
RobsCountach`'s Avatar
RobsCountach`
I've heard folks sit them in their oven (at low temps) to melt the glue and pull it apart; Do at your own risk (and it stinks).
Not to Hi-Jack the thread, but... Anyone know the purpose of that little window on top of the headlight ? Folks put those 'eyelid' things that cover it up. Always thought they're there since the car is so low, but sure that's NOT it.
Old May 31, 2019 | 11:13 PM
Rhettvette's Avatar
Rhettvette
I heard about the oven for the C6 lights but It's different for the C7. I didn't think they made a replacement lens but you never know there is always someone
with after market stuff. I don't think that light cost any more to make then say a Malibu but it's a Corvette so bend over.
Old May 31, 2019 | 11:20 PM
Have not seen any vendor offering a replacement for the C7 headlight lens. Perhaps some day one will step up.
Old Jun 1, 2019 | 08:52 AM
Null Pointer's Avatar
Null Pointer
Exception ID 10T
I think it was early 2018 that I saw vendors just starting to offer C6 headlight replacements - 5 years after the end of the C6 run. So it could be a while yet before vendors see enough demand to offer them for the C7. There were vendors offering just the lens before that, but you had to do the shake n bake oven routine to replace the lens on your existing housing.
Old Jun 1, 2019 | 07:13 PM
Avanti's Avatar
Avanti
I'll believe it when I see it.
Old Jun 2, 2019 | 11:17 AM
phileaglesfan's Avatar
phileaglesfan
Aftermarket will take over once GM no longer produces the OEM headlight like they did with the C6. And that was only 4-5 years after the last C6
To Headlight lens
