Delete codes
Old Jun 18, 2019 | 01:58 PM
JR01C5's Avatar
JR01C5
Default Delete codes
I borrowed an Actron Scanner to delete some codes the car threw and it won't. Any suggestions as to why it won't clear them. The car is a 14 1lt a6. Thanks in advance!
Old Jun 18, 2019 | 02:25 PM
Roastum1's Avatar
Roastum1
Probably a hard code. Was it emissions? There are hard and soft codes. You cannot erase the hard codes until problem is fixed.
Old Jun 18, 2019 | 02:53 PM
6Speeder's Avatar
6Speeder
On my 15 Z you have to get the car into "real accessory mode" to scan and delete. To do this you hold the start button down (clutch out) for 5 seconds.
Old Jun 18, 2019 | 11:57 PM
JR01C5's Avatar
JR01C5
Thanks for the info . I'll try to hold start for 5 sec and see what happens. If that doesn't work I'll just have to take it in then��
To Delete codes
