Your a young man!!! I just purchased my first corvette on jan 29th 2019 and have 9000 miles and it is not my everyday car.
It is a ton of fun to drive!! day one
I looked at the Range and the DiabloSport Predator and DiabloSport Intune. I'm eventually panning on a Magnuson Supercharger install which will delete the AFM, so no big deal for me.
No it will not mask it. Once it starts giving issues you will tell the shifts are jacked up even with the Range plugged in. Pull it out and you will experience terrible jumping. Best to trade it in afterwards for an M7 like i did.
It plugs into the OBDII port and prevents eco mode from ever engaging aka AFM (aftive fuel management) so the car never goes into V4 mode which supposedly exacerbates the shudder as the torque converter is working harder for some reason.
Bad idea, really bad. Covering up something that is potentially wrong.
You just can't let well enough alone, always think you're smarter than the GM engineers. Really?
Yes... read up. GM has no fix for the trans. Best to avoid it. They’ve revised the “fix” 3 or 4 times now. First it was replacement of converter, then trans, then triple fluid flush and new TCM tuning, then a totally new fluid and some folks still have issues. Multiple folks in our club have had all the fixes and still have the shudder.
Don't know about any "masking" but I installed my Range Technologies AFM Disabler at the 600 mile point and it will stay there until I sell the car. I never want to see the green "V4" on my dash ever again.
Don't wait too long to do the s/c otherwise you will definitely run the risk of damaging the TC. Better to buy the range for 179 bucks now as insurance against the shudder issue. Believe me you don't want to got through that. It took me the better part of three months in the shop to get my ZO6 straightened out with the shudder problem. I recently got a 2019 Grand Sport and the first thing I did was plug in the Range module with 6 miles on the OD.
The GM engineers blew it on this one. The Range disabler doesn't mask the problem; it prevents it from occurring by eliminating the constant clutching/de-clutching in the TC in V4 mode. If the shudder problem is already present the module won't do you any good. Damage is already done.
GM does have a fix for the 8 speed shudder problem and it works. I know as my car had the problem and the new 2019 flush took care of it. If you do your research you will see that the new fluid solves the problem 99% of the time. I had my fluid changed in late 2018 and that did not fix the problem but the new 2019 fluid finally did the trick, no more shudder.
The shudder problem happens in less than 10% of the cars with the 8 speed and GM has never given a good answer on why it doesn't happen to all of the them. It is not just the Corvette that has the shudder problem, it is ANY vehicle made with the 8 speed. I do agree with buying a extended warranty for peace of mine, I purchased the GM one for 5 years or 40K to be safe.
Attached is a GM Techlink article from January 2019 explaining why the new 2019 fluid solves the problem.
I wouldn't say it's that extreme that once the shudder is there you're effed, but if you drive it around shuddering for awhile, eventually you will damage the converter to where the new fluid won't help. If I were buying an A8 I'd install the range immediately and get the flush done.
John
I have to agree here. I had the shudder problem in my 2016 back in 2017. I had the original triple flush done and the shudder came back towards the middle of 2018. I purchased a range and installed it and the problem "went away" while the range was installed. I brought the car in this past March to have the new fluid change done and have been driving problem free for over 2500 miles now, without the Range device.
The range works to prevent the switch from v4 to v8, but I also discovered it prevents data from being captured / sent to OnStar and also prevents certain emissions data from being collected (this caused me to fail my emission testing the first pass). I had to drive without the Range device for 250 miles to get the emissions data captured.
I hope this works out fine for you but keep in mind that it generally takes 4-6K miles for the damage to the TC to occur. After 4 model years of GM fumbling around to fix the problem it seems too simple to be solely the fault of the fluid viscosity. The first triple flush routine was supposed to be the final fix for it and that obviously didn't work. We'll see this time around but for now I'm sticking to my Range module. The TC change was so much of a hassle over a several months period that I have no desire to repeat it.
OK... My Mercedes C350 would kill the engine when you stopped. I'm sure this added wear and tear on the engine. Mercedes added it to get the MPG higher and I disabled it. I'm assuming GM did the same thing to our C7 to raise the MPG.
Not that I purchased my C7 for a high millage car, but whats the MPG hit when V8 to V4 is disabled. I would do this in a minute, but $180 is a high price for it.. IMO. 1300 mile road trip last week got me 28.8 mpg. Same as my MB only my C7 has 150 more HP!!!
A hundred and eighty bucks is chump change when you compare it to the aggravation that comes with a damaged TC. Unless you're on a shoe string budget that few dollars shouldn't deter you from a little insurance against the potential TC problem.
If I have any issues in the first 3 years, I'll probably buy the extended warranty. You are correct, in that $180 is chump change. But you failed to add the loss in mpg. As I do believe all I read on the internet and feedback from Amazon customers, it looks like 3 mpg lose is normal. Range says 2ish. Using the 3 mpg loss in an 18 gallon tank, that would average out to about a loss of 50 miles per tank or 2 gallons of gas ($6 in my area) for each fill up or about 43 gallons of gas for 10k miles.
After 3 years (30k) and using this formula, the cost of the device and the loss of mpg would be almost $600. About 50% cost of a total warranty. I may be missing something and do want to avoid any TC issues... But also want to be cost effective in my choices.
All this said.... I still may buy it... Just would also want it out of my way... Not hanging down in my car.
