Remote start
Old Jun 24, 2019 | 01:37 PM
plmmd's Avatar
plmmd
Default Remote start
Just noted over the last week or so unable to remote start with the key fob- 2019 GS a8?? Any reason this might have occurred
Old Jun 24, 2019 | 01:40 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If you pressed the lock button and then pressed the remote start button, that should have done it. If not, then I'd suspect the FOB battery might be crapping out.
Elmer
Old Jun 24, 2019 | 01:55 PM
c54u's Avatar
c54u
You can remote start your car twice in a row and then the remote start is disabled until you physically get in the car with the fob and start the car with your foot on the brake. Also, you can remote start your car and extend the original run time by an additional 10 minutes by pressing the same fob sequence. Once the car shuts off after the time extension, you will have to start the car with your foot on the brake.
Try your other fob, try the phone app, or replace your fob batteries.
Good luck.
Old Jun 24, 2019 | 02:26 PM
Romark's Avatar
Romark
Is the hood open?
Old Jun 24, 2019 | 04:40 PM
javenius's Avatar
javenius
Are both doors closed completely?
Old Jun 24, 2019 | 05:14 PM
Rebel Yell's Avatar
Rebel Yell
Elmer
Had this happen to another brand vehicle. Even though the truck was only 3 months the battery in the FOB was too weak to get the signal out. It's cheap enough to try.
Old Jun 24, 2019 | 06:48 PM
owc6's Avatar
owc6
The car won't remote start if there is a CEL.
To Remote start
