Need tires size help MRR M755 Z51 replica wheels
I have searched a while and haven't found exactly what I need to know yet regarding tire size on these spec of wheels. I also heard about cracking fenders but haven't found any threads about that due to tires being too wide or offset issues.
I have a stock ride height Z51 with 19x9.5 50et and 20x11 73et wheels. I know they don't have the best offset, as they stick out a little, but I need wider than stock tires ASAP as a bad alignment has worn the inside of the fronts and outside of the rears. The 245/35r19 and 285/30r20 are too stretched on the 1" wider wheels. I would like to fit 275/30r19 and 305/30r20 on the car but don't know if they will rub and/or hit the fenders to the point of doing damage. The 275/30 have a better circumference (in keeping the F/R ratio for the BCM) than a 265/35 although I think the width of 265 should fit better. I only daily drive and will most likely be going with all season tires as the MPSS basically sucked for all but the 90+ degree days.
Does anyone know if I can get away with the tire sizes I mentioned? There aren't any in stock so I would need to have the tires ordered and that is where I am running into resistance with tire shops here, kinda a catch 22 as they won't order if they don't know they will fit or rub.
Thanks in advance!
Thanks in advance!
Minimal clearance when almost in 2 wheels
Car is up on my drive with 1 front in the air and the other rear half in the air to give an idea of wheel travel and clearance. Any thoughts?
Anyone?
The front will be fine. You will never be at speed with the wheel turned that much so a 265 or 275 will fit fine there. The rear will be close with a 305. I run a similar size rear wheel , but with a 76 offset moving the wheel in 3mm, am lowered on stock bolts all the way and with a 305 30 20 have to run -1.7* of camber and have trimmed my rear fenders to get them to clear.
Yourconfused (07-12-2019)
The comment that said that’s stupid low is totally bias. That car sits GREAT!!! The stock height looks horrible. If the op wanted a 4x4 I’m sure he would’ve got one. Nice car man.
Received 5,216 Likes
Wider tires/lower car may not always be possible without potential issues. Something to do with the Laws of Physics as I remember.
papillion (07-12-2019)
For reference, to those who can read that is, as I am stock height, I managed to fit the 275/30/19 up front with zero issue and love the increased traction. The 295/30/20 in the rear is a non issue, fitment wise, also but I wish I had access to a tire a bit wider as I could use more traction for my DD.
What tire did you end up getting? (You mentioned all seasons...)
I have a Z51 stock height that I'm gonna get all seasons for the stock rims and want to get some Nitto's on these ZR1 replica's. 19/20 running 265/305
https://www.ramseyethetrackguy.com/2...-indy-500.html
https://www.ramseyethetrackguy.com/2...ck-review.html
Yes. Lexani lx20. I did a lot of research and talked to people that have used them. They ride great, real grippy and are very quiet. There's also no skipping on full turn. Got them from Tires Nation. Best price and free shipping.
Have you gotten them hot yet? I noticed a few different brands tend to turn into grease when hot, as from hard driving/cornering to where your already warmed up tire temps go up a couple more degrees from the friction.
Also what alignment specs do you have and did you have any tire wear issues in the past?
Car looks really clean!
