Clutch fluid reservoir was nearly empty (M7 owners, check yours)
2016, 9k miles. I was having a squeaking/squawking sound engaging first gear from a stop. Sounded like the throwout bearing was going bad (someone posted videos of the exact sound here). Per a recommendation I checked the fluid level and sure enough it was nearly empty.
As I understand it GM fills it to "MIN" from the factory (why?!). Well, mine was underfilled or I have a leak. Re-filled with quality DOT 4 brake fluid to the 3/4 mark and it shifts better/quieter than when I got it new. I haven't heard the noise since but need to test more.
The following 2 users liked this post by chronage:
Bayshore Vette (09-09-2021),
Jayhawk94 (08-02-2019)
That is weird thank you for posting
Thanks for the heads up!
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
GM doesn't have to fill more because it should not use any fluid!
I do recall when I got my C6, many years ago, the cap was lose! But to have the reservoir empty would take more than a lose cap!
PS: It's NOT recommended you take the cap off very often. Brake Fluid picks up water is like a sponge. That is way they recommended always using a new container. I buy a new one each year (12 oz) when I Use the Ranger Method which takes about 7 empty, refill, 30 clutch pumps and repeat to get clear fluid. Once that aluminum seal on the opening is broken water vapor from the air will get at.
Nice catch, has source of missing fluid been discovered?
Had to go somewhere, sure didn't evaporate.
On C7 ZR 'RepoPilot' experienced something similar on a brand new ZR1.
Not only did his fluid disappear, it then returned!
Dealer cannot decipher IF it happened (no codes) nevermind where it went, apparently temporarily, only to return.
AH/SC acted wildly when this happened, car strongly pulled then returned to normal function.
I had the same thing happen to me when I purchased a 2016 Stingray from Carmax a couple years ago. I got the car home and started checking the fluids. When I pulled the cap off the clutch fluid reservoir, there was absolutely no fluid. Went back to Carmax and spoke to the salesman. We went over to where the vehicle had been parked and no fluid was seen on the ground. Never could figure out what happened, refilled the reservoir and it never gave me a problem in the year I owned the vehicle.
I guess I need to look at this when I get home.
goldend (08-02-2019)
There was an earlier thread where it was reported that low fluid level was observed from the factory, so perhaps this isn't unprecedented. Everyone should check theirs upon purchase.
Avanti (07-11-2019)
I have seen this before. my friends car was also very very low out of factory. Also a friend with a new C6 in 2013 also had no fluid in the Res. typical GM
Received 19,305 Likes
'20-'21-'22-'23-'24
I would certainly get the car checked over for a leak. And of course keep an eye on the level from now on.
This post made me go down and check the clutch fluid in my Z06. As I shared above, I had an empty clutch reservoir in my 2016 Stingray so I got a little nervous after looking at this post. Additionally, I've been experiencing a faint grinding noise/burning smell and clutch chatter. To my surprise (or maybe not so), the reservoir is nearly empty with just a small amount of dirty fluid lingering at the bottom. I bet a million bucks I've got a leaking slave cylinder that's responsible for the issues I've been having lately. Oddly, there is no fluid on my garage floor...this is probably a small, slow leak. I need to get this thing to the dealer ASAP.
Edit.... NM he was having the similar issue with his brakes...
Landru (07-11-2019)
Cruise-In VIII Veteran
If the C7 slave cylinder arrangement is anything like that on the BMW motorcycles with dry single plate clutches with which I am familiar (and I strongly suspect it is), the slave cylinder piston actually moves backward as the clutch wears, pushing fluid back to the reservoir. In other words, reservoir level *increases* as the clutch wears. Thus, the GM min level factory fill makes good sense.
hahaha and how do we confirm that? because if that be the case, then many ppl reading this thread who topped theirs off might have a little issue in the future, haha
Received 5,217 Likes
It's hard to believe, given previous experience with GM, that they would plan ahead for clutch wear. Might we think they are expecting differential fluid to increase with usage, as well?
Null Pointer (08-01-2019)
