Airbag code reader
Old Jul 18, 2019 | 07:59 PM
96GS#007's Avatar
96GS#007
Default Airbag code reader
2019 Grand Sport, M7. Car is all stock except brake pads and tires
During track days, without fail, my airbag light will pop on at some point during the session. Might be the first lap, might be the eighth, but it pops on. Turn the car off, restart it, and the light is off until next session. It does not and has not ever come on over the course of 4K street miles.
It’s almost certainly a loose connector but it could be a component as well. Rather than spending hours checking every wire, connector, and pin I want to pull the code(s) to narrow the search area. The only dealer I trust is 1-2 hours away depending on traffic.
That said....can anyone recommend a low cost diagnostic tool that can read the SRS (aka airbag) codes? Have you verified it can read the SRS codes on your C7 Many advertise they do...but it often turns out they don’t.
Old Jul 18, 2019 | 09:16 PM
Null Pointer's Avatar
Null Pointer
Exception ID 10T
Got this in an email from the tech support folks at BlueDriver. Might be hard to find one that does these functions on a GM product without spending a lot of coin.
"Your 2019 Chevrolet Corvette will support all features including enhanced codes with the exception of Airbags and TPMS diagnostics. Unfortunately in 2007 GM switched to a non-standard pin/protocol (#1/“gmlan”) for airbag and TPMS diagnostics, which is not compatible with the current version of BlueDriver."
Old Jul 18, 2019 | 10:07 PM
96GS#007's Avatar
96GS#007
Brutal
Thanks for the reply. Looks like I'll have to make the drive to the dealer.
Old Jul 19, 2019 | 12:55 AM
Jeff V.'s Avatar
Jeff V.
There's up to 18 modules on the low-speed GMLAN circuit. That thing is going to be missing a lot more than just airbags and TPMS...
OBDLink MX has the hardware to read low speed GMLAN, but I don't know of any software that'll actually perform those functions.
To Airbag code reader
