Long term storage
Old Jul 20, 2019 | 10:44 AM
F22md's Avatar
F22md
Default Long term storage
Hello!
I love this forum, but the search feature is worthless, so sorry to ask something that’s prolly been covered hundreds of times.
I need to put my C7 GS in storage for six long, painful, no good months. I was ready to put it up on floor jacks but then watched a video saying it may not be the best option for the suspension for long term storage. Should I just put it on flat spot preventers instead?
I’m not worried about the cost or the effort (of putting it on floor jacks or flat spot stoppers)...just need to know what the best option is for six months.
Old Jul 20, 2019 | 10:55 AM
Kracka's Avatar
Kracka
No need for either option; modern radials don't flat-spot. Get a battery tender if possible and consider some fuel stabilizer in a full tank of gas. Change the oil before or after storage, no need for both. Add an extra 5 psi to the tires. Unfortunately, winter storage is a reality for a lot of us. These cars are great though and fire right back up without a hiccup!
Old Jul 20, 2019 | 11:00 AM
F22md's Avatar
F22md
Copy on the fuel stabilizer/full tank and battery charger.
The tires on the GS are pretty soft and more prone to flat spotting than normal, all season tires. Based on everything I’ve read so far, it is better to avoid potential flat spots.
Old Jul 20, 2019 | 11:40 AM
Vette Ski's Avatar
Vette Ski
I thought someone reported "do not" store with a full tank. Check that out!
Rich
Old Jul 20, 2019 | 11:44 AM
JK 23112's Avatar
JK 23112
Trickle charger, tires lifted off the ground and fuel stabilizer added to the fuel tank to fight moisture & the ethanol. Do NOT store it with a full tank, though. There is some kind of sensor that can be damaged........at least from what I have read on this forum.
I would suggest a good coat of wax or sealant being applied before parking it - and a lightweight car cover suitable for indoor storage. This will help keep dust and debris off of the paint.
Good luck!!
Old Jul 20, 2019 | 11:51 AM
jimmie jam's Avatar
jimmie jam
I have not driven my car for 17 months. Over the years I have "stored" many vehicles for up to eight years without issue. Full tank of stabilized fuel, 40 psi tires, pump the brakes every few months and a tender. This is what I've done and do...what ever makes you comfortable.
Old Jul 20, 2019 | 12:07 PM
Kevin A Jones's Avatar
Kevin A Jones
Originally Posted by F22md
Hello!
First of all, 6 months is not necessarily 'long term" storage for a Corvette as many store their cars for 4-6 months over the winter. No need to jack up as any flats spots will be gone within your first mile or so of driving. Old Vettes (C2,C3s) with bias-ply tires will get flat spots.
You definitely need to connect your battery to a battery tender as C7s will de-charge over time. Many will recommend conditioning the fuel, however I don't unless being stored over 9 months to a year. I've never encountered a fuel issue after storing my cars.
Old Jul 20, 2019 | 02:59 PM
dvilin's Avatar
dvilin
Pump up the tires about 5 psi, hook up a battery tender, full tank of gas no additives needed and you are good.
Old Jul 20, 2019 | 03:17 PM
tobaccokid's Avatar
tobaccokid
aBe forewarned. The advice about a full tank is 100% wrong. You must leave the tank with no more than a 1/4 full tank. With a full tank and the car sitting for an extended period the sulfur in gasoline will corrode the fuel system control module located in the tank. You will be risking damage to the module and replacement (including much of the car that has to come apart), much of it labor, is a few thousand dollars for the complete repair.
Easy to confirm on the internet. See articles by Paul Koerner at Jackson (now Key) Chevrolet. Paul is one of the highest rated Corvette Dealer Specialists in the US and always has packed seminars at Corvettes at Carlisle.
Old Jul 20, 2019 | 03:41 PM
Zjoe6's Avatar
Zjoe6
1/4 tank myself, add some Startron fuel stabilizer, 5 psi to tires, battery tender. Good to go.
Old Jul 20, 2019 | 04:10 PM
Spitfire Mk1's Avatar
Spitfire Mk1
Formula 1
6 months is not a long time. I often store for 6 months or longer.
If oil and brake fluid hasn’t been changed in one year, I would change it. For the fuel stabilizer, I use Star Tron. I don’t trust ethanol fuel for several months. That said, if cannot get non ethanol fuel, using stabilizer should be ok. I come from camp of 1/2 tank. Mainly cause it may take many weeks to burn a nearly fuel tank after storage. Btw, I either store on a lift, or inflate tire 10 pounds and park then under thick carpets.
That said, I would be mostly concerned with rodents. There are many threads about how to avoid them, and seal up / protect your car.
Old Jul 20, 2019 | 10:20 PM
No real need to jack the car up to keep the tires off the ground. Just add a few PSI of pressure and you'll be fine.
Old Jul 20, 2019 | 10:26 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
first of all....lots of good info here...
flat spotting a non issue as said add 5psi and hook up a battery tender maybe crack the windows 1/8 inch and throw a cover on it
fuel I have stored a car for 6 months or more with varying levels of fuel and never an issue
my question is where do you live / plan on storing it? that info may help with more specific issues related to your specific weather
To Long term storage
