From time to time my HUD moves and I need to use the switch to re-align back to where I like it. I'm not inadvertently hitting the switch with my knee or anything. I still have a full range of movement so I don't think anything is loose.
Has anyone else experienced this? I'm not too concerned... just curious.
Mine seems to be tilted a little bit, is that not normal?
The left side is a little higher than the right side.
What year is your car? The later models have an adjustable HUD. Earlier models do not. It's the windshield that causes the offset. You can tell this by moving your head down. As you get lower the HUD alignment straightens right out. The curve in the windshield glass causes the distortion. The switch was added to allow drivers to compensate for this distortion.
Mine will do that once in a while, too. Not often, maybe three or four times in the five years I've owned the car. It is a 2014 so it only has the vertical adjustment.
What really got me was the first time all the windows and the sun aligned perfectly and I could see the below-dash workings of the HUD unit reflected in the windshield. I thought something was really haywire until I finally came to a curve on a long desert highway.
Mine is a week old today--2019 GS 2LT A8, Sebring Orange
Where would a switch for that be?
Thanks Nathan....
Thanks Nathan....
EDIT-Congrats on the new 2019 GS -end of edit
2019 user manual here... I think the 2018's also have the rotation functions in the DIC. No control to move the HUD display right or left unfortunately.
Reason: Congrats
Yes Sir Thanks that last part was what I needed worked perfectly.
I know longer have to tilt my head to the right to read my HUD.......lol.......
