Expel over Ceramic Coating
Old Jul 28, 2019 | 08:18 PM
Dwilly's Avatar
Dwilly
Default Expel over Ceramic Coating
Looking at doing Expel on my car, and I’ve been told it won’t stick since it’s already been ceramic coated. Anybody had Expel applied after ceramic coating and if so did it stick??
Old Jul 28, 2019 | 08:28 PM
madrob2020's Avatar
madrob2020
What I’ve seen on here, including responses from paint film installers, is always film first. PS: Ceramic coating is quite difficult to remove.
Old Jul 28, 2019 | 08:43 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
My understanding is the adhesive on the PPF won't adhere properly to ceramic
Old Jul 28, 2019 | 08:54 PM
Dwilly's Avatar
Dwilly
I understand you should coat over film, but car has already been ceramic coated. I’m not looking to wet sand the car.
Question-
“Has anyone had GOOD luck putting Expel over ceramic coating”
Old Jul 28, 2019 | 09:10 PM
KenHorse's Avatar
KenHorse
Question-
Xpel says no. Seems to me that should answer your question
Old Jul 28, 2019 | 09:20 PM
The Xpel should be installed first, so if you have the ceramic coating on now, withougt removing the coating you may be out of luck.
Old Jul 28, 2019 | 09:46 PM
Dwilly's Avatar
Dwilly
👌👌—Thanks Captain Obviousl!!
I know what Expel says and all the so called rules!!
I’m looking for a first hand response from someone that has done or attempted along with results!!
Old Jul 28, 2019 | 09:48 PM
madrob2020's Avatar
madrob2020
😮 wow, just wow 😲
Old Jul 28, 2019 | 09:49 PM
jh225's Avatar
jh225
St. Jude Donor '14
Go to the Autogeek forum and search how to remove ceramic coating..........https://www.autogeekonline.net/forum/
Old Jul 28, 2019 | 09:55 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
..or you could give it a try and report back with results?
Old Jul 28, 2019 | 10:01 PM
KenHorse's Avatar
KenHorse
As expensive as Xpel is, I doubt there are many willing to find out if the manufacturer is wrong.......
Old Jul 28, 2019 | 11:19 PM
G8ME's Avatar
G8ME
I ceramic coated my car and had Suntek applied to the hood afterwards and its not had a problem sticking was so ever, can't speak for Xpel though.
Old Jul 29, 2019 | 12:52 AM
Grzldvt1's Avatar
Grzldvt1
����—Thanks Captain Obviousl!!
I am a pro detailer and the ceramic coating has to be removed first. It won't stick.I know a famous person that thought I was nuts and went somewhere else. The first time they took their car to the car wash the Expel on the floor of the car wash. However it does not have to be wet sanded, if your installer knows what they are doing the ceramic can be buffed off with a good compound, polished back upon and the film installed. He came in to my shop, realizing I knew what I was talking about to have it installed correctly
To Expel over Ceramic Coating
