Remove the Range AFM before service?
Old Aug 2, 2019 | 08:50 AM
DGA3's Avatar
DGA3
Default Remove the Range AFM before service?
I am taking my 2017 Z06 in for the electronic steering assist recall service and - if I remember correctly - think that I need to remove my Range device before dropping off my car.
Is this correct?
I know that the Range does not affect the warranty or anything, but I'm guessing that the tech will have to use that port at sometime, so the device should be removed.
Any other advice on the subject?
P.S. The Range has been a wonderful addition to my A8. Things are much better without the car going into 4-cylinder mode.
Old Aug 2, 2019 | 09:11 AM
Kevin A Jones's Avatar
Kevin A Jones
Yes, remove the range devise prior to service and drive approx 200 miles to clear. You can use manual shift during that times to keep out of v4 mode.
Old Aug 2, 2019 | 09:17 AM
Maxpowers's Avatar
Maxpowers
For sure - they will likely use the OBD port.
Old Aug 2, 2019 | 09:36 AM
kennyjames21's Avatar
kennyjames21
Has anyone had their warranty affected by the range device?
Old Aug 2, 2019 | 10:07 AM
quickblue02's Avatar
quickblue02
I took my 2019 in for its first oil change at Parkway Chevy in June. I forgot to take out the Range out. The oil change guy at Parkway removed the range, plugged in his reader and then put my Range back in. No big deal. They see them all the time.
Old Aug 2, 2019 | 10:10 AM
orca1946's Avatar
orca1946
I'll still try tp remember to remove it b 4 service to eliminate any concerns.
Old Aug 2, 2019 | 10:33 AM
bjones7131's Avatar
bjones7131
Never heard the 200 mile thing, I just removed before my last oil change and plugged back in.
Old Aug 2, 2019 | 11:16 AM
TXSteveF's Avatar
TXSteveF
I only had to remove mine and drive the 200 miles so I could pass the emissions testing. That's the only reason I'm aware of that would make you need to remove it but I'm no expert in this. My service guys have never seemed too bothered by it in the past but I do try to remove it before I drop it off.
I've always wondered why GM cares about them if in the long run it does help the TC issues and in theory saves them money. You'd think they'd be encouraging their use under the table so to speak. They can't openly push for their use due to the gov regs and all.
Old Aug 2, 2019 | 02:05 PM
Oh4GTO's Avatar
Oh4GTO
Is it that hard to unplug it from OBD port to start a whole thread on it?
Old Aug 3, 2019 | 12:19 AM
I would unplug it when going in for service. While it doesn't change anything that would be a warranty issue, it is simple enough to just umplug, get service done, then re-plug the device into the OBD port.
Old Aug 3, 2019 | 12:24 AM
GRSAMS's Avatar
GRSAMS
Same here.
Old Aug 3, 2019 | 12:31 AM
Avanti's Avatar
Avanti
Any time a dealer flunky(and who know who will deal with ones car) has to muck with anything, it may not matter what logic would or would not dictate, much less how many Range devices they might have seen. Just remove the d**ned thing and be safe about it!
Who knows; they might even toss or "lose" it since it will likely be in their way and it is not authorized by GM. The latter might make it tough to do anything about it.
Old Aug 3, 2019 | 07:25 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
I unplugged mine and put it in the console. Drove 30 miles, they did the Multi Point Inspection and used the OBD Port. When I got back in the car I plugged it back in and went on my merry way!!!
Old Aug 3, 2019 | 09:01 AM
Elk's Avatar
Elk
Whenever I forget and leave something plugged into the OBDII port on any of may cars, the servicing shop merely unplugs it and leaves it on the console. Trivial.
Do not overthink this.
To Remove the Range AFM before service?
