Check Engine Light
Old Aug 11, 2019 | 07:24 PM
plake's Avatar
plake
Default Check Engine Light
2015 Z51 M7, out of nowhere yesterday on a start up saw the check engine light. Steady not flashing. 2 more starts still there. 8500 miles, what’s up?
Old Aug 11, 2019 | 07:26 PM
owc6's Avatar
owc6
What are the code (s)?
Old Aug 11, 2019 | 08:00 PM
dave_2012_tt's Avatar
dave_2012_tt
In general a solid check engine light will not cause damage. A blinking one generally will. Give the age of the corvette going to go with a sensor. If it came on during drive I would go with a MAF but this one going to say oxygen sensor.
Old Aug 11, 2019 | 08:16 PM
owc6's Avatar
owc6
I agree with your advice about solid vs blinking with this: don't drive it if it's Blinking longer than it takes to get to a safe spot and have it towed.
​​​​However, w/o codes it could be darn near anything. We can guess all day long.
Old Aug 11, 2019 | 08:30 PM
Dcasole's Avatar
Dcasole
Here we go let me pull out the diagnostic dice ... what's up ??? Just get the codes read and you will know what's up
Old Aug 11, 2019 | 10:39 PM
KemahGT's Avatar
KemahGT
Autozone around here will come out to your car and read it for you. Have them reset it no matter what the results are.
Respond with the code(s) and you may find more help on here. Put it in the Tech section. Good luck!
Old Aug 12, 2019 | 06:45 AM
cowboy casey's Avatar
cowboy casey
While a little more expensive than most I can reset almost anything and can live monitor anything going on. Worth every penny I paid... Most get the little bluetooth ones and they also work...
https://smile.amazon.com/gp/product/B0090B7M2O
Old Aug 12, 2019 | 08:15 AM
plake's Avatar
plake
Going to the dealer and let them read code. Should be under warranty, 5 year 60,000 power train I hope.
Old Aug 12, 2019 | 08:22 AM
Dcasole's Avatar
Dcasole
Good Luck , please let us know how it works out at the dealer
Dave
Old Aug 12, 2019 | 10:08 AM
JMII's Avatar
JMII
Yep I got a Bluetooth OBD-II dongle along with the app on my iPhone. It has saved me multiple trips to the dealer on various cars. Can also stream live, real time engine data to the app to monitor things as you drive.
For example I had a CEL pop up on my Dodge truck, so I pulled the code and it turned out to be bad power steering pressure sensor. Watched a 5 minute YouTube video on how to replace the $18 sensor, super easy fix! Also found a bad cam position sensor in my previous Nissan. Another easy and cheap fix because I knew the exact part that had failed. Well worth having a way to read various codes.
Old Aug 12, 2019 | 12:18 PM
Jmhornz71's Avatar
Jmhornz71
2015 has 5 year 100k mile powertrain warranty
Old Aug 12, 2019 | 01:09 PM
plake's Avatar
plake
Well even better on the warranty. Dealer plugged in and no faults or existing faults, CEL is still on. Nothing shows, back on Thursday to have them look at it.
Old Aug 12, 2019 | 01:22 PM
NSC5's Avatar
NSC5
With the CEL on there are one or more active DTCs set. The dealer should also have been able to read the historic DTCs that were set.
Hopefully they do better next time! Many of the basic consumer level code readers cannot retrieve codes set by some of the modules but the dealer level equipment certainly can. Various controllers other than the ECM, like the TCM, will send a request to have the CEL illuminated and that request DTC links back to additional codes stored in the module. There is a good chance the fault originated outside of the engine/emissions systems but unless the dealer was using a scanner from "the dollar store" it should have provided a listing of the DTCs regardless of which module or subsystem set them.
Old Aug 18, 2019 | 01:06 PM
plake's Avatar
plake
Well I start the car to go to dealer and no check engine light. I went anyway and had them print codes.
U0402
U0401
P0731
All in history status.
Old Aug 18, 2019 | 02:14 PM
NSC5's Avatar
NSC5
I would suspect a communications issue with the TCM, but basically you have a communications error between the engine and transmission control modules. Sometimes oddball codes get set when the battery is getting too old and voltage drops unexpectedly during a start sequence so if you are on your original battery this could be it. P0731 is reporting an incorrect gear ration in the first range which generally means a mismatch between the input, intermediate, and output shaft speeds in the transmission but a glitch from low voltage could have caused an error with the shaft speed sensors.
To Check Engine Light
