Outside door opener
Old Aug 12, 2019 | 06:58 AM
Stingrayfish's Avatar
Stingrayfish
Default Outside door opener
I have a 2019 Stingray and most of the time opening the doors from the outside I have to press the door opener 2X. Anyone else having this issue?
Old Aug 12, 2019 | 07:37 AM
JDSC8VETTE's Avatar
JDSC8VETTE
It happens often. Not a big deal. I think there may be a delay if you grab the handle quickly. It may just be the car recognizing the key fob a bit slow.
Old Aug 12, 2019 | 10:15 AM
cowboy casey's Avatar
cowboy casey
you FOB battery may be getting low.. I have noticed it takes a few seconds longer to see the FOB if my cell phone is over it in my pocket..
Old Aug 12, 2019 | 10:43 AM
Z06_Ruff's Avatar
Z06_Ruff
St. Jude Donor '19
I have the same issue at times. I think it's pretty normal. I had the same issue with my C6.
Old Aug 12, 2019 | 11:00 AM
ImpliedConsent's Avatar
ImpliedConsent
Seems to me that your Passive Door unlock feature is not working. I don't know about the 2019, but my 2016, press SETTINGS on the Home Page on the infotainment system display and the options will show. Scroll down to Passive Door unlock.
Old Aug 12, 2019 | 11:07 AM
w0rM's Avatar
w0rM
Works every time if you have a fresh battery. The key fob gets really flaky as the battery starts to wear out.
Old Aug 12, 2019 | 02:38 PM
fsvoboda's Avatar
fsvoboda
What all the above guys said. It's sometimes a little flakey for whatever reasons.
Old Aug 12, 2019 | 05:55 PM
Avanti's Avatar
Avanti
It only happens if released too quickly. Hold the release a moment longer and the issue should disappear.
Old Aug 13, 2019 | 10:53 AM
Maxpowers's Avatar
Maxpowers
Yeah mine takes about a second of holding to unlock.
Old Aug 13, 2019 | 12:15 PM
JDSC8VETTE's Avatar
JDSC8VETTE
This is very common on most vehicles. Sometimes we are too quick and don’t give it enough time to release. I do it often with my Honda Pilot. I grab the handle and pull it before it has a chance to unlock the door. You need to take your time and hold it till it opens.
Old Aug 14, 2019 | 02:32 AM
owc6's Avatar
owc6
Settings have nothing to do with this issue. You cannot turn off passive unlocking.
Most likely culprit is a low fob battery, low car battery or some interference in descending order, however, dirty door pads are starting to be likely given the age of our oldest C7s.
Old Aug 14, 2019 | 12:29 PM
JMII's Avatar
JMII
Door Dogs = problem solved.
After getting my C7 I had immediate hate regarding that hidden touch pad. I found the doors were tricky to open plus I was getting finger prints on them when closing. The Dogs solved both issues.
Old Aug 14, 2019 | 11:33 PM
Vegas1500's Avatar
Vegas1500
Cool concept but not a fan of the look......
To Outside door opener
