C7 transmission
Old Sep 3, 2019 | 03:04 PM
Maud's Avatar
Maud
2nd Gear
Default C7 transmission
My 2015 z51 automatic has a very slow sloppy shift from 1st to 2nd gear. Dealer has reprogrammed 4 times. Still terrible. What is the fix.
Old Sep 3, 2019 | 03:18 PM
Flame Red's Avatar
Flame Red
You mean 1-2 slow when the engine is cold, right? Not when the engine is at normal operating temp. Nature of the beast - that is how it is. Snappy once the car is fully warmed up.
Old Sep 3, 2019 | 03:23 PM
speed4tu's Avatar
speed4tu
I traded my 2016 A8 equipped one for a 2018 M7. That seemed to fix my issues.
Old Sep 3, 2019 | 03:46 PM
captain vette's Avatar
captain vette
well done ! nothing can beat a MT equipped car.
JonMN's Avatar
JonMN
I had a 2016 A8 for 3 years. Little by little I went to using M mode all the time. It takes time to get used to this, as there really seem to be optimum shift points. Not counting WOT which is fun but impractical most of the time. I found the 1-2 shift to be fast and smooth if you either shifted right away once you get moving (even if as low as 1 to 1.5K RPM or so) or, it was also quick if you were accelerating quickly and shifted at over 2.5 K or so. It would really hang if you hit the wrong RPM in between, With time it got to be a reflex and I got pretty good at it. M mode can be a lot of fun. If you are passing, for example, hold down the downshift paddle and it drops to the lowest safe gear. Manual downshifting for curves is also a blast.
(Then I took the approach of speed4tu above and traded for a 2019 GS M7 . . .)
Old Sep 3, 2019 | 04:17 PM
MMD's Avatar
MMD
TSB 19-NA-121 which came out July 9 2019 fixes this issue, as well as the well known A8 shudder problem, I am having with my vehicle and will be in for service at my local Chevy Thursday to fix this shifting problem. They will perform a flush as well as replace with a new synthetic tranmission oil. Should take around 3-4 hours to do. Strongly recommend you change over to the new fluid. The new transmission fluid is a more robust fluid than the old oil they had been using prior to February 1, 2019.
Old Sep 3, 2019 | 04:20 PM
Maud's Avatar
Maud
2nd Gear
Yes. Always slow when cold. Now starting when warm after 10000 moles.
Old Sep 3, 2019 | 04:23 PM
MMD's Avatar
MMD
Keep the moles out of the transmission!
To C7 transmission
