Removing lug nuts
Old Sep 6, 2019 | 07:43 PM
Matthewstorm's Avatar
Matthewstorm
Default Removing lug nuts
I'm changing out my lug nuts. The car is back up a couple inches on Rhino ramps. I took off and replaced the lug nuts on 1 front wheel no problem. I went to change the back wheel, on the ramp, and on the 3rd nut the whole car shifted. In a panic I replaced the lug nuts and backed away. Is it ok to replace the lugs with the car flat or does it need to be jacked? Thanks.
Old Sep 6, 2019 | 07:46 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
They're acorn nuts and they'll self center. No problem without jacking the car
Old Sep 6, 2019 | 07:47 PM
Matthewstorm
I noticed the car righted itself after replacing the nuts but it kinda freaked me out.
Old Sep 6, 2019 | 07:59 PM
RonC7's Avatar
RonC7
Changing one lug nut at a time on the ground is fine. Then use a torque wrench,
PatternDayTrader's Avatar
PatternDayTrader
Why dont you just change them.one at a time ?
Old Sep 6, 2019 | 08:19 PM
Avanti's Avatar
Avanti
Sorry, but I never do it in such fashion. I lift each tire, in turn. I do all five nuts together, all off, all on, torquing cross-wise to 50, 80, and 100#s. It may not matter with "modern" parts but that's the way it has always been recommended by manufacturers I can recall
Old Sep 6, 2019 | 08:29 PM
Obe1 GS's Avatar
Obe1 GS
You've described the process if you've removed a wheel and then replacing it. Removing/replacing one lug nut at a time with the other four fully torqued does not require jacking the tire off the ground.
Old Sep 6, 2019 | 08:37 PM
Matthewstorm
What do you mean by 50, 80, 100? I understand the torque is supposed to be 100lbs. I'm using a impact wrench to remove and install then I'll use a torque after.
Old Sep 6, 2019 | 08:42 PM
Exia's Avatar
Exia
Keep the car on the ground, replace one nut at a time, tighten to 100 foot pounds. I only ever came across one nut that gave me grief, I literally had to stand on the wrench to loosen it, I guess someone at the factory had a field day. The car during the entire process did move backwards and forwards on occasion as i would tighten/loosen nuts but it was fine. No need to jack up the car. Drive it around for a few miles and retighten all the nuts.
Old Sep 6, 2019 | 10:03 PM
speed4tu's Avatar
speed4tu
Did you really try and take them all off while the car was on the ground?
Matthewstorm
Well, one wheel at a time.
Old Sep 6, 2019 | 10:05 PM
speed4tu's Avatar
speed4tu
If youre using an impact to take them off and put them back you have already overtightened them unless youre using a torque stick on the gun to put them back with. Don't put them back on at all with the impact unless you have a torque stick or you will probably need new rotors bc you will likely warp them.
Old Sep 6, 2019 | 10:32 PM
That is the way I have always done it too. Perhaps it can be done one lug at a time while still on the ground, but I just prefer to do it my way.
Old Sep 6, 2019 | 10:38 PM
Walt White Coupe's Avatar
Walt White Coupe
Sounds to me like you should take your car to a mechanic and never touch a wrench.
Old Sep 6, 2019 | 11:07 PM
Matthewstorm
Why, because I'm trying to learn?
Old Sep 7, 2019 | 09:23 AM
Maxpowers's Avatar
Maxpowers
OP. As others said, you're perfectly fine doing one at a time.
Old Sep 7, 2019 | 10:19 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
No problem. 1 nut at a time can be done with the car sitting on the ground. Just torque each nut to 100 lb ft.
Elmer
To Removing lug nuts
Old Sep 7, 2019 | 05:35 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If you mean removing and replacing 1 nut at a time, so there are always 4 tight ones, that should be ok. Use a torque wrench.
If you mean removing more than 1 while there is weight on the wheel, I wouldn't do that.
Old Sep 7, 2019 | 11:23 PM
Matthewstorm
Got a torque wrench, removed and replaced 2 at a time. Torqued 50, 80, 100, as recommend by someone here. Discount Tire had jammed the torque waaaay past tolerance on some nuts. Easy peasy.
Old Sep 10, 2019 | 12:24 PM
Widgeon5's Avatar
Widgeon5
What you tried to do was unwise for several reasons, including your personal safety. That you did not perceive this on your own, even without any "learning", suggests that you do not have natural mechanical aptitude and would be better off letting others work on your car. In no way am I implying that you are not intelligent. Albert Einstein is reported to have left home in the morning without his pants.
