2015 stingray . the reading lamps, (on each side of the rear view mirror), are on all the time the engine is running. Pushing the button for on/off do nothing.. Read the manual and found no help.. Anyone experience this or know a fix.. thanks
2015 stingray , by reading lamps, (on each side of the rear view mirror), are on all the time the engine is running. Pushing the button for on/off do nothing.. Read the manual and found no help.. Anyone experience or know a fix.. thanks
There is a button on the dash to the left of the steering wheel that controls dash lighting, when turned all the way clockwise, it turns the courtesy lights on.
EVERY single owner of a C6 (press) or C7 (turn) has done this at least once.
If they don't own up to it, they are lying or very well read.
It is well-hidden behind the the steering wheel. Most folks trigger it while cleaning.
99% of the time the map lights , dome lights, interior lights whatever you want to call them are part of the dimmer switch. For as long as I have been driving if I wanted the interior lights to go on I went right for the dimmer switch and turned it clockwise until it clicked. And if I didn't want them on and somehow they were on I always knew the dimmer switch must be involved. I can't understand car people who don't know this stuff. Is this the first car you ever owned? So no I for one am not owning up to it.
