I would want at least all-season tires for New York. The tires that you have now will be dangerous to drive on when the temps drop below 40 degrees Fahrenheit (some say 50 degrees). If you have room to store a second set of wheels you might consider a second set of wheels with Winter Tires instead of the All-Season tires. Put them on in the Fall and take them off in the Spring. If you buy two different styles/colors of wheels you can alter the look of your C7 according to the season. I enjoy the heck out of swapping out the wheels and seeing the transformation. Michelin makes a Winter Tire they call the Pilot Alpin PA4 that grips like crazy in crappy, cold weather.
