Dash lights
Old Sep 13, 2019 | 07:45 PM
CourtneyJudd's Avatar
CourtneyJudd
Default Dash lights
I started my 2014 Z51 up after installing the 1 to 4 th bypass on the transmission and after about 15 seconds the dash lights went to dark. The HUD stayed lit and could vary the brightness with the dash ****. I did this while I was getting a X-pipe installed. Now the dash lights come and go with no apparent reason. Co-incidence or problem somewhere else.... any ideas would be appreciated! Thanks, CJ
Old Sep 14, 2019 | 09:12 AM
Grand Slam's Avatar
Grand Slam
Neither of those mods should have affected the dash lighting.
The HUD brightness is controlled by the lever, the dash brightness is controlled by the ****. Which brightness were you adjusting?
If you haven't already done so, try changing the dash brightness in case there's a spot which is flaky.
Old Sep 14, 2019 | 09:33 AM
CourtneyJudd
i was adjusting the lever but will mess with the **** later today and see what happens.... figured this just had to be co-incidence. I'll let you know what sorts out! Thanks, CJ
Old Sep 14, 2019 | 03:52 PM
Jmhornz71's Avatar
Jmhornz71
You cant adjust the dash brightness during the day, it only can be adjusted when the sensors say its dark out, a long thread on this
Old Sep 14, 2019 | 04:43 PM
4thC4at60's Avatar
4thC4at60
That's not exactly right.....
If you had your dash lights dimmed for better night vision and you start the car up in the day the dash lights will be still be dimmed. While they will only adjust to X-brightness.... as soon as you drive into the light the lights will stabilize for day time driving. Had to adjust mine in the garage just this morning.....
Old Sep 14, 2019 | 05:13 PM
CourtneyJudd
well, I tried to adjust the dash lights this morning while parked in the garage and absolutely nothing happened... so I figured I had a sure nuff problem ... so glad to see that was normal. At least the dash lights were normal or lit... maybe they will stay this way. I'll have to do some more experimenting but thanks for the info! CJ
To Dash lights
