Steering recall
Old Sep 23, 2019 | 10:00 AM
Gunny27's Avatar
Gunny27
Veteran: Marine Corps
Default Steering recall
Has anyone had the steering rack recall performed yet? Does it require a frontend alignment? My car is in the shop starting today for the second A8 trans flush now that they have the new fluid. They are also going to swap out the steering rack for the recall if they have one in stock.
Old Sep 23, 2019 | 11:02 AM
Pineapple's Avatar
Pineapple
I recently had the steering recall done. Only the front toe will be adjusted back to factory spec. Chevy will only cover that alignment setting for the recall. If any other alignment value is out of spec you’ll need to cover that cost.
