With our product, we have had only one instance, that was a Camaro 6th Gen 3.6L V6 having issues with AFM disabler and our TC. Disconnected the AFM disabler and it worked fine. If you use a TC setting with high enough sensitivity AFM will hardly activate as it depends on throttle rate. We are sure there must be many others using AFM disablers w/ our TC, but we have not heard of any issues. I wish we could give you a more conclusive answer but that is all we know so far. You have zero risks when you buy from us, whichever the outcome. Thx.
I am using the Soler TC/TB and the Range device. 0 issues
I also have the Soler TB and throttle controller with a range (also BMS filter and Borla X pipe) and have had zero issues. They all work flawlessly together.
I also have the Soler PTB and TC along with a Range device, AFE intake and Borla x-pipe. No problems whatsoever. In fact, they work beautifully together. I even have a Window Valet plugged into a dual OBD-2 plug adapter and even that performs with zero problems.
P.S. - The Soler PTB and TC are awesome!! They really wake the car up.
I bought the exchange TB and a TC. I took my original one off and boxed it up for a refund on the core.
I had to giggle a little because I called Soler today and asked if I need a RMA or other number so I could be sure I get the refund on core.
He replied, "No RMA, we are very small company." He explained that they use the name on the shipping label for reference, so a RMA is not required.
I am impressed with the TB, I hope the cord on the TC is long enough that I can hide controller in my center console.
Ken
Thanks, Ken. We only use RMA's for warranty claims. I giggled too when you asked about the core return department. I wish we were big enough to have departments :-). Right now it is an office, a lab, and a machine shop in the same building. I truly believe that the smaller the company the tighter it runs, some companies are so big that they cannot see their own feet, then nothing can be simple anymore.
Your core and refund are safe, Ken. We still can put two and two together.
BTW, if the extension is not long enough for the place you would like to place your TC display, just send us an e-mail and we'll send a 3-ft extension.
