Which spring do I need? (leaf spring went bad/popping noise)
So my 2015 Z06 w/Z07 has a bad front spring. The car was making a popping noise and I found the end of the spring is splitting badly. So I need to order a replacement. Which spring is the correct replacement:
I have attached a pic of the bad spring for reference in case anyone else comes across this thread with the same issue. The symtoms started about a year ago with an occasional popping noise making tight turns in parking lots. Now a year later it makes a lot of popping or creaking noises when coming to a stop at a stop sign. The problem was difficult to diagnose!
I am guessing the dealer you order the spring from will need your Vin# so the correct spring will ordered. The Vin# should tell dealer & GM what the car came with.
I agree with the above two posts - seems like the Z07 would be the heavy duty spring and the dealer should be able to tell you what the car came with using the VIN.
