Some folks would say to read the manual but I am not some folks. If the passenger has set the right hand temperature and seat controls differently than the left side, touching the sync button will restore the right to the values of the master control.
SYNC: Press to link all climate zone settings to the driver settings. The SYNC indicator light will turn on. When the passenger temperature setting is adjusted, the SYNC indicator light turns off.
In layman's terms it means that if the SYNC light is lit both of the climate control temperature settings will be the same; if you adjust the driver's side it will change the passenger side to the same setting.
