Winterization
Old Oct 16, 2019 | 10:52 AM
BELVIN20's Avatar
BELVIN20
This link of the gas tank issue is a good one to watch.
https://www.corvetteblogger.com/2018...erm=2018-12-07
Old Oct 16, 2019 | 10:53 AM
Que Rich's Avatar
Que Rich
I’m always curious why do people put their cars away completely in the winter? Is it because of the tires? I drive mine all year. Of course I don’t drive it in crappy weather/road conditions but I don’t put it away
Old Oct 16, 2019 | 11:05 AM
rickferrell's Avatar
rickferrell
Default winterization
When connecting a battery maintenance product do you need to disconnect battery terminal to prevent electronic damage
Old Oct 16, 2019 | 11:11 AM
rickferrell
is it necessary to disconnect battery when on tender to prevent any electronic damage
Old Oct 16, 2019 | 11:13 AM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
That wouldn't be very convenient.
Old Oct 16, 2019 | 11:36 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The stock summer tires should not be driven or even stored below 20’f, according to GM.
In practice, storing where the temperature drops to 0 for short periods seems to be ok if you don’t move the car or do anything like getting in/out that flexes the tires.
Everyone, including me, has their own technique for winter storage- how much fuel, how much tire pressure, when to change the oil, etc.
In practice, it doesn’t seem to matter for just a few months.
Old Oct 16, 2019 | 12:16 PM
Patman's Avatar
Patman
Originally Posted by Maxie2U
Do not fill up your tank because it could screw up the tank sensor. I personally would NEVER leave old oil in the engine.
You really think 500 mile oil is old and needs to be changed?
Old Oct 16, 2019 | 12:19 PM
Patman's Avatar
Patman
If the roads are full of salt and snow I definitely don't drive it but when I get a nice dry day with clean roads in the winter I'll take it out as long as it's not below about 25F. Lucky for me I can find quite a few days each winter like that so my sports cars have very rarely sat for the entire winter without being driven (the winter of 99-00 was the exception here, I couldn't drive my 98 Formula for 4 solid months)
Old Oct 16, 2019 | 12:42 PM
Boxcar's Avatar
Boxcar
Life Starts at 120 mph
NCM Lifetime Member
K, agreed that everyone has an opinion. I live in Up...Way... Upstate NY. My 2 cents
1. Inflate tires to 36 PSI and drive the car onto foam matting to sperate tire from concrete.
2. On my C3,4,6 I was filling the tank, however, after reading further then just CF I believe 1/4 with non-ethanol 91-93 is good. The first thing I do in spring is add and injector cleaner, fill it up and I'm off.
3. Oil change every April-May regardless along with annual safety inspection and wheel alignment.
4. Battery maintainer on, no disconnection of battery, never had an issue even with C6. I hooked directly to the battery posts. Note: long term disconnection leads to loss of driving data on the onboard computer. Am I wrong?
5. Last thing is to crack...very little crack of my favorite air freshener and close it up.
During the winter months when a warm spell hits, I will fire it up bring everything to operating temperatures A/C, heating, oil and coolant. Run the heating to warm and dry out the interior.
Again, my 2 cents, and that time is coming soon.
Cheers Boxcar
Need to update my Avatar...things to do this winter.
Old Oct 16, 2019 | 05:12 PM
C7LOU's Avatar
C7LOU
Are there any issues with removimg the battery for 6 months?
Old Oct 16, 2019 | 07:32 PM
guido7834's Avatar
guido7834
Old Oct 16, 2019 | 10:11 PM
taz2016's Avatar
taz2016
In my part of the country it can take until spring for all the salt residue to be off the roads. I have two other vehicles with AWD that I don't mind when they contact a corrosive agent.
Reason 2 - My prep for my Vette for storage includes hand washing which I find to be rather inconvenient in freezing weather
Old Oct 16, 2019 | 10:17 PM
  #33
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
What is this "winter" of which you all speak of?
Old Oct 17, 2019 | 08:24 AM
  #34
speed4tu's Avatar
speed4tu
This is what i'm trying to figure out as well. Everyone is storing their car and i'm sitting here like, its finally cool enough to remove the targa top!
Old Oct 17, 2019 | 08:59 AM
  #35
rrsperry's Avatar
rrsperry
That's a tough one... WInterize? Yep, put the all season tires on it. Done...
Old Oct 17, 2019 | 09:05 AM
  #36
DGA3's Avatar
DGA3
I thought they weren't supposed to be driven when the temps are below 40 degrees (F), not 20.
Yes? No?
Old Oct 17, 2019 | 09:33 AM
  #37
rickferrell
can you answer the question ?
To Winterization
Old Oct 17, 2019 | 02:39 PM
  #38
Gearhead Jim
St. Jude Donor '13
Yes? No?
The Owner Manual for our 2017, p. 266, recommends not driving the summer tires below 40'f, and says they can crack if stored below 20'f. Obviously, if they can crack from being stored at that temp then they shouldn't be driven at that temp. The 40' number is for tire grip, the 20' number is for tire cracking.
rick ferrel
Yes, but I don't spend my entire life on Corvette Forum.
Old Oct 17, 2019 | 04:02 PM
  #39
joemessman's Avatar
joemessman
Good advice. You'll be presented with a bill of around $4,000 to repair a fouled sending unit. Labor is a killer.
Old Oct 17, 2019 | 09:09 PM
  #40
Dale124's Avatar
Dale124
This tire issue is really driving me nuts. I live in Alberta, where winters get CCCCCOLD! I do not have a heated garage, so, I am now worried about if my tires will survive the winter. I will not be driving it at all once it gets cold, and I thought that would be enough to not have tire damage. I have to wonder what all the dealerships do with their cars that have high performance tires on them. I can’t imagine that they have room to store them all.
I am sure that I am not alone in this situation, so, are any of you facing the same problem? Is this tire issue being over thought?
Dale
