Towing a C7
Old Nov 2, 2019 | 11:32 AM
16 AGN's Avatar
16 AGN
Default Towing a C7
I have a 2019 C7, I want to have some way of pulling it up on a wrecker if something happens. I have installed the permanent aluminum pucks for jacking. Is there another place to hook a small J hook if I purchase a long V-bridled tow strap.
Old Nov 2, 2019 | 11:47 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You can buy a Tow hook, a Genuine GM tow hook, it screws into the superstructure through the front grill or the rear fascia. Be Very Careful not to buy one of those fake colorful tow hooks, from Amazon or eBay. ( THEY ARE FOR SHOW ONLY).. you see them in different colors, they are aluminum and cost around 25 to 35 dollars. A solid steel tow ring with the proper thread pitch ( they are around 100 dollars and ( Gene at Cultrag ) sells them and is a safe method since most tow companies do not carry every type of screw in tow hook.
Bill
Old Nov 2, 2019 | 12:41 PM
See this thread for some recommendations:
https://www.corvetteforum.com/forums...r-your-c7.html
Old Nov 2, 2019 | 04:38 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
I have the straps and the pucks. I keep a tool with me to remove the pucks in case I need to use those straps in those locations.
Old Nov 2, 2019 | 05:03 PM
Kevin A Jones's Avatar
Kevin A Jones
Don't know there is a 'safe' place to hook tow strap into except the frame hold-down slots. Don't see the purpose of permanent pucks myself. I keep the removal ones in my truck cubby along with my tow strap.
Old Nov 3, 2019 | 06:21 AM
Mitch03Z06's Avatar
Mitch03Z06
Do you mind sending me the link where you purchased the strap. Thanks
Old Nov 3, 2019 | 07:50 AM
Kevin A Jones
https://www.ebay.com/itm/302742672841
Old Nov 3, 2019 | 08:31 AM
mountainears
Here's the one I bought.
https://rover.ebay.com/rover/0/0/0?m...2F291177211318
Old Nov 3, 2019 | 08:48 AM
449er's Avatar
449er
CF Community Team
Does anyone know if these bridles would work on a C6?
Old Nov 3, 2019 | 09:20 AM
Kevin A Jones
Be sure to order the strap specifically for the C7 that's long enough to clear the bumper as mine does below. Earlier straps were too short and did not. I know because I initially received one that was too short in that it didn't clear the underside of C7.
ORDER:
YOU ARE BUYING ONE (1) CORVETTE C7 V-BRIDLE WITH T&J COMBO MINI FRAME HOOKS GRADE 70 WHICH HAS A WORKING LOAD LIMIT OF 5,400 LBS. THE LEGS ARE 80". THE D-RING IS 10,000 LBS. THE WEBBING IS 20,000 LB. SINGLE PLY WITH EDGE GUARD FOR EXTRA DURABILITY.
NOT:
YOU ARE BUYING ONE (1) V-BRIDLE WITH T&J COMBO MINI FRAME HOOKS GRADE 70 WHICH HAS A WORKING LOAD LIMIT OF 5,400 LBS. THE LEGS ARE 29" AND THE TOTAL LENGTH IS 38". THE D-RING IS 10,000 LBS. THE WEBBING IS 20,000 LB. SINGLE PLY WITH EDGE GUARD FOR EXTRA DURABILITY.
Old Nov 3, 2019 | 12:58 PM
JFJr's Avatar
JFJr
Yes, buy the GM tow hook and don't go cheap on your expensive car. The hook fits perfectly in the battery compartment for storage.
Old Nov 3, 2019 | 03:09 PM
Kevin A Jones
It's not a question of going cheap, it's more about using what works best. Some tow truck operators won't use the tow hook to load a C7 on to a flatbed as it's off-centered. A tow hook is basically used to get a car on or off the track.
The "centered" tow point provided by a strap connected to the factory tie-downs provides a much easier and safer tow point than an off-center tow hook.
Old Nov 3, 2019 | 03:16 PM
Bill Dearborn's Avatar
Bill Dearborn
Yes, C5, C6 and C7 all use the same T hooks through the slots in the frame. I am still using the T Hooks I purchased to trailer my 97 when I purchased it in 97. I purchased a V Bridle to pull my C7 up on the trailer since I didn't like the way the tow hook screwed into the front of the car snapped and turned while the winch pulled the car up on the trailer.
Bill
Old Nov 7, 2019 | 09:10 AM
16 AGN's Avatar
16 AGN
Received my strap yesterday through the mail. Strap looks exactly like your picture, quality product. After checking it out put it back in the bag that came with it and stored in the cubby. Just hope I never see it again!
Old Nov 7, 2019 | 03:39 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Be aware that although all C7's have the slot in the battery area lid to store the hook, not all C7's have the threaded receivers front and rear to use the hook.
Old Nov 7, 2019 | 04:07 PM
Difflow's Avatar
0Difflow
Former Vendor
Don't go cheap is my advice
To Towing a C7
