Tire width/diameter effecting ABS and PTM
Old Nov 4, 2019 | 12:43 PM
havasu486's Avatar
havasu486
Default Tire width/diameter effecting ABS and PTM
With so many different tires out there how does different overall width and diameter effect the ABS and PTM? Is there any acceptable range of difference of those provided from the factory? In my case C7 Grand Sport
Old Nov 4, 2019 | 03:24 PM
6Speeder's Avatar
6Speeder
Supposedly, changing the diameter percentages, front to rear, can affect ABS and possibly PTM. The stock diameters are 96.8% smaller front to rear. I am running 18" wheels all around with tires giving a 98.7% difference (closer to the same size), front to rear with no problems whatsoever. On my C5 (yes, a while back) I ran tires that were the same diameter front and rear, with no problems. I believe as long as the fronts are smaller in diameter than the rears you'll be OK.
