Wrong way driver in Phoenix
With a diamond design (which saves land, and is chosen where cities are already built up) the driver has to chose either the left lane or the right lane to enter an expressway depending on the direction they wish to travel on the expressway.
The mistakes are made on the left turn lane (but can be made from the right hand turn as well). In the image above, if you were traveling on the road, left to right and you wanted to drive up the vertical expressway, you would enter in the left lane AFTER crossing over the expressway. Here is where the mistake is made (and the exact mistake this Corvette driver made.) Instead of turning left AFTER the expressway, he turned left BEFORE he crossed over. This put him on the Northbound EXIT ramp, so he ended up on the northbound side going southbound. Make it 1:30 in the morning after drinking all night and this isn't hard to do.
Many other cities use the cloverleaf design. Here, you always enter the expressway with a right hand turn. Never a left. It is almost impossible to enter on the wrong side in a cloverleaf. You might chose the wrong ramp and not going in the direction you want, but at least you won't be one the wrong side of the expressway.
The only way to end up on the wrong side of the expressway in a cloverleaf design is if you were already driving on the wrong side of the street before you entered. Cloverleafs take up significantly more real estate to build.
[img]https://cimg6.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/600x404/cloverleaf_2f8405454e54dbb69d54c90712f6b 6be54a50b5a.jpg
[img
They look like an accident that is waiting to happen.
At each of these intersections, you will enter the expressway from the right hand lane to go one direction or the left hand lane to go in the other direction.
If you are traveling north on 87 and want to go west on 60 there will be a stoplight at 1, then you will proceed to a second stoplight at two. This is your lefthand turn onto 60 West. The drunk at 2:00 am, sees the cue up sign for the 60 West, but turns left at the first stop light at 1. This puts him/her on the exit ramp from the 60 East. They are now traveling westbound in the eastbound lane.
Same thing can happen on the right hand turn to go East on 60. The entrance ramp is at 1 the first stoplight, but if the drunk goes through the first light then turns right at the second light, they would now be going onto 60 east in the westbound lanes.
Keep in mind, the drunk doesn't see all those red WRONG WAY signs the state is making bigger and bigger. They also fail to see the thousands of red lane reflectors as they travel in the wrong direction. This is mostly a DUI issue, far more than some senior out at 2 am and getting confused while sober.
You cannot make these two mistakes on a cloverleaf design.
Which is what SingleTrackMinded was asking about. Can't get more off base than that!
That's what he and I were asking - where are these? And you point out several of them that do not match this "diamond" design.
Yes and there's nothing wrong with that. We were not talking about this style of entrance to a highway. In fact, it was you that said:
