Screw loose..ok missing
Old Nov 16, 2019 | 03:37 PM
yellow2007's Avatar
yellow2007
Default Screw loose..ok missing
Si I back up onto the new ramps to check clearance for when I do my tranny flush. Not quite high enough so it's back to the floor jack and stands. While under there though I see I am missing a chassis bolt. It appears the threaded portion is in but the bolt shaft/head have broken off. I've had to remove such bolts in the past for work but this one I'd rather not screw with given the torque that must have been applied to it. Off to GM parts to at least identify the bolt and have one on hand.
Old Nov 16, 2019 | 04:36 PM
laserdude2215's Avatar
laserdude2215
Wow! What about the other side? I would not be driving the car like that.
Old Nov 16, 2019 | 04:56 PM
Dcasole's Avatar
Dcasole
Are u sure that's not the locating pin ??
Dave
Old Nov 16, 2019 | 05:31 PM
Exact1's Avatar
Exact1
Dave
Yep, bet it's a locating pin. Look close at the pic.
Old Nov 16, 2019 | 05:46 PM
yellow2007's Avatar
yellow2007
Are u sure that's not the locating pin ??Dave
T
heres one on the other side and if you look close you can see where the washer on the head of the bolt was.
Old Nov 16, 2019 | 06:10 PM
Zjoe6's Avatar
Zjoe6
What's this?
Old Nov 16, 2019 | 07:10 PM
Makitso's Avatar
Makitso
I would replace all the bolts on the rear cradle, probably over torqued with an impact.
Old Nov 16, 2019 | 07:25 PM
yellow2007's Avatar
yellow2007
Originally Posted by Zjoe6
What's this?
That's a good question. I will look in more detail the next time I am under there. I've ordered two new bolts just in case but I do know the transmission had been replaced before my purchase. Now to find the torque value..........
Old Nov 16, 2019 | 08:37 PM
laserdude2215
Wonderful. Now you need to be suspicious of every fastener that the previous shop touched and there are a lot of them.
Old Nov 16, 2019 | 08:41 PM
yellow2007's Avatar
yellow2007
My thoughts exactly. I could forgive over torquing but not leaving it like that. That's just shoddy workmanship.....
Old Nov 16, 2019 | 09:19 PM
RonC7's Avatar
RonC7
Default Torque Values
Several tables up in the master list of how-to sticky
https://www.corvetteforum.com/forums...ue-values.html
https://www.corvetteforum.com/forums/c7-tech-performance/3498092-specifications-frame-and-underbody-fastener-tightening-torque-values.html
Old Nov 16, 2019 | 11:45 PM
Avanti's Avatar
Avanti
Don't over-think it. I've seen people twist-off one bolt and not damage any others. Hope one is all you have trouble with. It's possible.
Old Nov 17, 2019 | 12:03 AM
Missing bolts would certainly worry me. Good luck getting it fixed.
Old Nov 17, 2019 | 08:35 AM
Bigredwing's Avatar
Bigredwing
Do you have a wider shot of showing the location?. My car is on a lift and since I'm now curious I would like to check it (not that I expect anything). Thanks.
Old Nov 17, 2019 | 09:43 AM
yellow2007's Avatar
yellow2007
The locator pin is just to the left
To Screw loose..ok missing
