Active Rev Match
Old Nov 19, 2019 | 05:19 PM
Bluevette16's Avatar
Bluevette16
6th Gear
Default Active Rev Match
Hello, my ARM Stopped working this morning, and after Shutting down the C7. I noticed that the Fan continued to Run..Will the ARM Reset after being completely shut off over 24 hours, And why would the Fan continue to Run ?
Old Nov 19, 2019 | 05:25 PM
dvilin's Avatar
dvilin
You have to turn on ARM every time you start the car, normal for the fan to run after you shut it down for a few minutes.
Old Nov 19, 2019 | 05:39 PM
Bluevette16
6th Gear
Default Active Rev match
Yes, i know that. But upon clicking the levers, it doesn't turn to orange,and the fan ran for 20 minutes this morning after Shutting off the engine at 4AM.
Old Nov 19, 2019 | 06:09 PM
Maxpowers's Avatar
Maxpowers
How old is your battery? Weird things happen when the battery gets old.
Old Nov 19, 2019 | 06:15 PM
Bill Dearborn's Avatar
Bill Dearborn
Fan will run after the engine is turned off.
Bill
Old Nov 19, 2019 | 06:29 PM
dvilin's Avatar
dvilin
Sorry I have not heard of any similar problems with ARM or the fan running for 20 minutes after shutting the car down You can try disconnecting the battery for 10 minutes and then reconnect see if that does anything. Or take it in to the dealer and let them take care of it.
Old Nov 19, 2019 | 07:48 PM
c6txvette's Avatar
c6txvette
You have a thermostat issue man, you might eventually get a p0128 code and check engine light. When my failed my arm did not work and my fan ran on high for like 15 minutes after car was turned off
Old Nov 20, 2019 | 08:14 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
What was your temperature running?
Old Nov 20, 2019 | 08:39 AM
Bluevette16
6th Gear
I honestly don't remember
Old Nov 20, 2019 | 07:38 PM
Bluevette16
6th Gear
Default Active Rev Match/Thermostat
Well. I got in the C7 to drive it home from work, a commentor, asked what the Temp was. It never went above 100. So made sn appointment with the dealership to have it checked out. Then i did a little research, found my code reader, plugged it in an..Walaaa.. code P1028. So i cleared the code and started it back up. Added a little coolant and drove dow the highway and came back home, and No continuation of the Engine fan running. Btw, after i cleared the code the Temp went up to about 190, upon stabbing hard on the accelerator i noticed the temp went up to a normal temp around 220. So I'll see what Happens on the way to work in the morning.. THANKS TO ALL WHOM GAVE ME ADVICE AND INSIGHT..#Bluevette16
Old Nov 20, 2019 | 08:32 PM
Avanti's Avatar
Avanti
Did the ARM work okay, then, too? Welcome to the wonderful world of digital controls... great when it works right.
Old Nov 20, 2019 | 11:54 PM
Bluevette16
6th Gear
Default ARM/ Fan..
Yes, came right on
To Active Rev Match
