Cabin air filter
Old Nov 29, 2019 | 11:24 AM
frankb's Avatar
frankb
Default Cabin air filter
I have a 14 and I had changed the cabin filter a yr. ago but think I put it in wrong. First does it follow the tracks in the hole that make it go up on a angle or some how lay flat. Second does the arrow go for air flow, facing up or facing down. I have look at different u tube and still can't get it right. Thanks Frank
Old Nov 29, 2019 | 10:46 PM
kaplana08's Avatar
kaplana08
Arrow faces down.. Should just slip in. simple. You may have to sqweeze the ends a little bit so it goes in easier. Brands other than GM can be slightly more difficult to slip in.
Old Nov 29, 2019 | 11:28 PM
Seems like my filter laid flat.
Old Nov 30, 2019 | 12:10 PM
kaplana08's Avatar
kaplana08
[QUOTE=frankb;1600570411]I have a 14 and I had changed the cabin filter a yr. ago but think I put it in wrong. First does it follow the tracks in the hole that make it go up on a angle or some how lay flat. Second does the arrow go for air flow, facing up or facing down. I have look at different u tube and still can't get it right. Thanks Frank[/QUOTE
Yes there is a slight angle when filter goes in. You can see that by looking at the old filter which became slightly bent in time from the angle
Old Nov 30, 2019 | 09:26 PM
frankb's Avatar
frankb
I just found a schematic and on the 14 it does go back up on a angle. Thanks for the help
Old Jan 24, 2020 | 06:59 PM
jipper's Avatar
jipper
Anybody tried a scented air filter? I know they have these for Mercedes wasn’t sure If they made one for vettes
Old Jan 24, 2020 | 11:33 PM
LT4CMG's Avatar
LT4CMG
I went with the boring OEM option, but pick me up a stripper glitter scented one if you find it.
Old Jan 24, 2020 | 11:45 PM
owc6's Avatar
owc6
And, just exactly what does glitter smell like?
Enquiring minds want to know.
Old Jan 24, 2020 | 11:46 PM
LT4CMG's Avatar
LT4CMG
cheap perfume and many regrets
Old Jan 25, 2020 | 06:25 AM
cowboy casey's Avatar
cowboy casey
I have used this Fram in both of my C7's and they work great, fit exactly the same as OEM...
My vert needed it changed BADLY, I don't think the previous owner even knew it had a cabin filter....
https://smile.amazon.com/gp/product/B00EAOIRDO
Old Jan 25, 2020 | 05:16 PM
naylor99's Avatar
naylor99
Oh wow! That looks completely clogged up. I bet you can feel the difference!
Old Jan 26, 2020 | 12:55 AM
Kracka's Avatar
Kracka
Fram FreshBreeze is typically my preferred, but I may try K&N's reusable next.
Old Jan 26, 2020 | 07:00 AM
jipper's Avatar
jipper
Is the scent mild or overpowering?
and to be clear...:I was looking for a scented air filter that was mild and fresh if such a thing existed
Old Jan 26, 2020 | 08:39 AM
Kracka's Avatar
Kracka
Sounds like you probably want the K&N then.
Old Jan 26, 2020 | 08:56 AM
jipper's Avatar
jipper
is it scented? I saw one with febrewze but said unscented
To Cabin air filter
