Battery tender
Old Dec 2, 2019 | 07:10 PM
prlywhts's Avatar
prlywhts
2022 C7 of the Year Finalist - Unmodified
Default Battery tender
Can anyone recommend a battery tender that plugs into the cigarette lighter? Doesn’t need to have Corvette logo if works better at half the price. TIA
Old Dec 2, 2019 | 07:36 PM
laserdude2215's Avatar
laserdude2215
How about works the same for a little less?
https://smartercharger.com/products/...18547596886116
You will also need the adapter.
https://smartercharger.com/products/...18547587514468
Old Dec 2, 2019 | 07:44 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Ctek makes good ones. Just be sure to plug it in to the hole in the trunk, not the dash.
Elmer
Old Dec 2, 2019 | 08:18 PM
radrush's Avatar
radrush
That's a good one, but I like this one..
CTEK 5PK748190 Silver MUS 4.3 TEST & CHARGE 12 Volt Fully Automatic Charger and Tester
Amazon Amazon
Old Dec 2, 2019 | 08:44 PM
Vegas1500's Avatar
Vegas1500
CTek with the adapter plug.
Old Dec 2, 2019 | 08:49 PM
SonnyAK's Avatar
SonnyAK
Agree on the Ctek! We have 5 of them running all the time on various vehicles. Also have a couple of cheaper brands and while they seem to run fine, I have much more faith in the Ctek to maintain properly on the newer cars that have a lot of electrical drain.
Old Dec 2, 2019 | 09:10 PM
Obe1 GS's Avatar
Obe1 GS
The older CTEK 3300 model does a great job and can still be found for under $69
Old Dec 2, 2019 | 09:34 PM
EJ1's Avatar
EJ1
Default VDC Electronics BatteryMINDer® Model 2012
I’ve used this model for years with great results on 3 different cars over 10 years
Buy the optional lighter adapter when you buy the unit (adapter is 2nd link)
http://www.batteryminders.com/12-vol...-worldwide-use
https://www.batteryminders.com/12-24...cle-power-plug
Old Dec 2, 2019 | 09:44 PM
Apocolips's Avatar
Apocolips
I have one of these. I've had it for over 10 years and used it on several different cars. It works great.
Battery Tender Jr. Battery Tender Jr.
Adapter Adapter
Old Dec 2, 2019 | 10:11 PM
runner61627's Avatar
runner61627
I have used this CTEK for six years. Very satisfied with purchase.
Amazon Amazon
TBBE's Avatar
TBBE
Default Battery Tender
May be a silly question BUT it’s getting a bit colder so I’m looking at putting up my C7, what exactly does the battery tender do? & do I park in garage & plug in every day it’s in the garage or ?????
Old Dec 2, 2019 | 10:13 PM
saleen556's Avatar
saleen556
If you still drive it regularly then it’s not needed. If you go weeks without driving it it’s a good idea to put it on the charger. Especially in the cold weather.
Old Dec 2, 2019 | 10:15 PM
runner61627
It’s primarily used as a battery maintainer when storing or not using your vette for any prolonged period. With the amount of electronics that remain active in a C7 while parked, your battery will drain after a few weeks.
Old Dec 2, 2019 | 11:34 PM
If this is for a C7, why not use the GM accessory one that plugs into the outlet in the hatch. If for another car, some good recommendations have been given.
Old Dec 2, 2019 | 11:47 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
When a battery sits for long periods of time, it build up sulfate crystals. These crystals impede the development of electricity and reduce the charge and hold status..A tender with a desalination cycle will remove these crystals. The better Ctek MUS 4.3 8 step charger/ tender has this superior cycle..
Its what I use.
Old Dec 3, 2019 | 06:00 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I have been using the same CTEK on my C6 since 2012. If it ever dies I will be getting another CTEK.
Old Dec 3, 2019 | 07:35 AM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
I'm with EJ1 on the recommendation of the BatteryMinder Plus and adaptor. This model also disulfates like the better
CTEC units. I got mine on sale from Northern Tools.
To Battery tender
Old Dec 3, 2019 | 07:37 AM
Mayor111's Avatar
Mayor111
Its called Battery Tender for a reason...this has been bullet proof for years...get this Tender and the adapter and you can use it on all your cars
Tender:
https://www.amazon.com/Battery-Tender-021-0128-Maintain-Damaging/dp/B00068XCQU/ref=sr_1_1_sspa?keywords=battery+tender+plus&qid=1575376562&s=automotive&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyQ09KWEtQQTRNMzRWJmVuY3J5cHRlZElkPUEwMDE5MTg5RVlFR0VMN09YNFVZJmVuY3J5cHRlZEFkSWQ9QTAyNTYyODIzT1hDQ0xaTVJMNVBSJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== https://www.amazon.com/Battery-Tender-021-0128-Maintain-Damaging/dp/B00068XCQU/ref=sr_1_1_sspa?keywords=battery+tender+plus&qid=1575376562&s=automotive&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyQ09KWEtQQTRNMzRWJmVuY3J5cHRlZElkPUEwMDE5MTg5RVlFR0VMN09YNFVZJmVuY3J5cHRlZEFkSWQ9QTAyNTYyODIzT1hDQ0xaTVJMNVBSJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Adapter:
Amazon Amazon
Old Dec 3, 2019 | 09:43 AM
Prray's Avatar
Prray
I recommend the CTEC MUS 4.3, I have 2 of them-best chargers I have ever owned.
Old Dec 3, 2019 | 01:04 PM
ersatz928's Avatar
ersatz928
Get a Deltran Battery Tender.Plus...I have had one for 20 years...rugged metal case...not cheesy plastic...
http://products.batterytender.com/Ch...derR-Plus.html
You can find these for $39 to $45.
The Battery Tender® Plus is a 1.25 amp battery charger designed to fully charge a battery and maintain it at proper storage voltage without the damaging effects caused by "trickle chargers". Included is a quick connect ring terminal harness for hard to reach areas and alligator clips for an alternate connection.
  • Temperature compensated to ensure optimum charge voltage according to ambient temperature.
  • Automatically switches from full charge to float charging mode.
  • Reverse Polarity Protection to ensure user safety. Red & Green Lights Alternately Flash in this condition.
  • Complete 4-step charging program (Initialization, Bulk Charge, Absorption Mode, Float Mode).
  • Perfect for all lead-acid, flooded or sealed maintenance free batteries (AGM and gel cell).
  • Safety timer: 72 hrs.
  • Certification: UL/CSA. FCC.
  • AC Power Cord Length: 6 ft. - 18AWG
  • DC Output Cord Length 4.5 ft. - 18AWG
  • DC Accessory Length 1.5 ft. - 18 AWG
  • Weight: 3.0 lbs.
  • 10 year Warranty!
