Ceramic brake pads
Old Dec 5, 2019 | 03:30 PM
salsno's Avatar
salsno
Default Ceramic brake pads
Looking for experienced advice on replacing factory brake pads with ceramic. Who makes the best ones? I am in Upland CA 91784 area...know a good mechanic who could do the work? I just bought this 2019 ZO6. The car as about 1100 miles on it. Thanks!
Old Dec 5, 2019 | 04:11 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
You are going to here many replies on this subject including use the search function but I will give you my 2 Cents and everyone else will chime in with there two cents.
For a high quality low dust performance street pad take a look at the Carbotech 1521 brake pads.100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and can be ordered online here http://ampdautosport.com/brake-pads/corvette/ or call me at 216-780-8825. The part numbers you need are front CT1405 and rear CT1718 they are listed under the C7 ZO6 section. Use promo code z28 at check out to receive your forum discount.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old Dec 5, 2019 | 04:18 PM
Mayor111's Avatar
Mayor111
My vote is for PowerStop pads - used them on my 12, my 14 and soon to be installed on my 17... Virtually dust free, awesome stopping power and simple to install.
https://www.powerstop.com/
Old Dec 5, 2019 | 04:41 PM
redman76's Avatar
redman76
St. Jude Donor '09
I'm assuming you are looking for low dust pads? I went the Carbotech 1521 path which I'm very satisfied with, but as Adam said, if you do a search for C7 low dust pads, you'll read about other options including the PowerStops. To search, go to the Search tab above, then click on the Advanced Search link.
Old Dec 5, 2019 | 05:00 PM
salsno's Avatar
salsno
Thanks a million...will investigate. Appreciate your response.
Old Dec 5, 2019 | 06:07 PM
JMII's Avatar
JMII
Happy Power Stop user here with a Z51... they produce very little dust and perform great, so I recommend them.
I really didn't have massive hate for the OEM Brembos, they dusted more then average but I am used to aggressive track pads so
Old Dec 5, 2019 | 08:28 PM
Ken_4fun's Avatar
Ken_4fun
These are the ones I installed almost immediately after getting my car. I would say the at least as good as the factory (maybe a tad better), and absolutely no problems or dust.
Recommend them, but probably others are just as good.
Ken
Old Dec 5, 2019 | 09:11 PM
SingleTrackMinded's Avatar
SingleTrackMinded
I swapped my OEM pads with Carbotech 1521's. Happy with them. No issue. Brake dust considerably reduced.
Old Dec 5, 2019 | 09:25 PM
Chipn01's Avatar
Chipn01
Powerstop seems to-be about 1/2 the cost , are carbotech really worth the difference. I could be reading the sites wrong , just asking
Old Dec 6, 2019 | 06:42 AM
Mayor111's Avatar
Mayor111
That's why I chose PowerStop - I could not believe the insane prices Carbotech was charging for pads...
Old Dec 6, 2019 | 08:58 AM
DGA3's Avatar
DGA3
Powerstops here for my 2017 Z06.
Love 'em!
Old Dec 6, 2019 | 09:09 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I swapped my OEM pads with Carbotech 1521's. I did this as soon as I got the car home from the dealer. Dust free, no burnish, no breakin procedure. It took me longer to jack the car up than it did to swap out the pads in my garage. Very easy to do.
Elmer
Old Dec 6, 2019 | 10:14 AM
Chipn01's Avatar
Chipn01
Which ones z23 or z26’s
Old Dec 6, 2019 | 10:26 AM
JMII's Avatar
JMII
Z23 - some discussion here: https://www.corvetteforum.com/forums...re-tricky.html
Compounds are the same, the backing plate seems to be the only difference. On the street, even in "aggressive" driving you are just not generating that much heat. Maybe if you do mountain / canyon runs then having a more heat resistance backer might be advisable.
Old Dec 6, 2019 | 11:25 AM
Chipn01's Avatar
Chipn01
Interesting post - wonder if others are having the squeak problem? The powerstop pads are really affordable. Like $60 for the rears. Hey maybe just try em and see. If squeak use em for boat anchors.
Old Dec 6, 2019 | 11:29 AM
Mayor111's Avatar
Mayor111
Since the Vette is a "performance" vehicle, I would suggest the Z26 pads... Sure the Z23 pads are enough...but for the minimal $50 (+/-) price difference, why not go for the performance pads...just my .02 cents
Old Dec 6, 2019 | 11:31 AM
Ken_4fun's Avatar
Ken_4fun
No, if they squeak send them back for refund.
My Powerstops only squeak after I have washed my car and put it in the garage. They stop squeaking before I leave the driveway.
Ken
To Ceramic brake pads
Old Dec 6, 2019 | 01:15 PM
Chipn01's Avatar
Chipn01
Roger that!
Old Dec 6, 2019 | 01:28 PM
Flame Red's Avatar
Flame Red
I replaced the OEM with the CarbonTechs from a forum vendor here and it just still had way too must for me. After 1k on the clock the wheels were pitted and peeling from brake dust. I then swapped out to PowerStops and much less dust. Mine is street use.
Old Dec 6, 2019 | 01:36 PM
AlexM's Avatar
AlexM
Power Stop here as well, very happy so far and an acceptable price tag.
